Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Hi
It could be a power supply problem or an inverter board problem or something internal having to do with the backlighting of the unit. remove the inverter, and look at the back side and you will see a hot spot, now on the other side of that hot spot, re-solder the service mounted components and that should take care of your problem.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
