Optics Logo
j
jerry pierce Posted on Mar 31, 2016
What is the year model of my rifle ?
What is the year model of my rifle.it is a marlin model 922m
5 Related Answers
strech3030us
Strech
  • 1562 Answers
  • Posted on Mar 28, 2014
SOURCE: I'm trying to see what year my marlin lever action rifle is.
1883
Found here:
http://oldguns.net/sn_php/marlinlookup.php
ddywrbks
Michael Anderson
  • 799 Answers
  • Posted on Jun 04, 2014
SOURCE: Want to find out age of marlin model 336 lever
mfg. in 1973
gregmk
  • 204 Answers
  • Posted on Jan 19, 2015
SOURCE: How to determine the model and serial number of a marlin 22 rifle?
this is copied from a site, the web address is pasted below.
The serial number depending on the model of rifle, will be located either on the upper or lower stock tang, or side of the receiver.
http://www.gunvaluesboard.com/marlin-serial-numbers-dates-of-manufacture-1664.html
also if you find serial # you may find more info here.
From 1962 thru 1968 Marlins rimfire rifles (other than the 39 series lever actions) used a two letter date code that was stamped on the barrel. This date code is different than the one already listed, as Marlin rimfire rifles (other than the model 39 series) did not have a serial numbers until required to by Law after 1968. The first letter of the date code represented the month of manufacture while the second letter indicated the year. This date code was usually stamped on the left side of the barrel just in front of the receiver.
redjack33720
RichardL
  • 157 Answers
  • Posted on Aug 15, 2016
SOURCE: My Bushnell Banner rifle scope
Same as the other guy who asked....and it's more common than you'd believe....try turning the knob all the way THE OTHER WAY. It sounds like you're going backwards on the elev knob.
ccallaghan
coty
  • 14 Answers
  • Posted on Apr 07, 2017
SOURCE: How much is my marlin tube 22 rifle worth, ser. nu. 25326873
On gunauction.com You can find them between 65-120 depending on shape, age, shipping cost. I bought on for 72 plus 20 shipping.
1helpful
Serial # range for marlin model 60 with 18 shot tube and last shot bolt hold open
On Marlin-branded Model 60 rifles, the first two digits of the serial number indicate the year of manufacture. For example, if the serial number starts with 18... The 18 is significant, for subtracting it from 2000 gives the date of manufacture for the rifle, 1982. Likewise, a serial number starting with 17 would be a rifle manufactured in 1983.
This method has not been uniformly followed. It is valid only from 1971 through 1999. Prior to 1971, the first two digits indicated the year of manufacture. For example, a rifle with a serial number starting with 70... would have been made in 1970. Starting in 2000, this same old method has returned; the first two digits once more indicate the year of manufacture directly, with no subtraction required.
Can't find year of my rifle marlin model 1893 and
Try typing in on Google...Marlin rifle serial numbers. There should be a list with all the info you need
Sep 02, 2014 • Optics
What year was my Marlin 30-30 with serial number 6014444 made?
TRY THIS LINK
Top Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you an Optic Expert? Answer questions, earn points and help others
