Panasonic Videoprojector PT-LM1E Multimedia Projector Logo
I
IBRAHIM ISMAR Posted on Mar 30, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lcd projector panasonic model pt-lm1e when we input power. red light appear, then nothing even press power button. and small red light from circuit blink several time what is a problem?
When inplug power to projector yellow and then red light,but power button wont fuction to make projector to fuction out.stil in red light and other red light from circut blink several time...plz help what the problem?
Tariq rasheed
Level 1:
  • Contributor 1 Answer
  • Posted on May 05, 2020
Tariq rasheed
Contributor
Level 1:
Answers
Questions
0
Helped
370
Points
Input power botan red light.on.next not prossess.and not on green light
  • Tariq rasheed May 05, 2020
Pieter Vleeshouwers
Level 3:
  • Panasonic Master 2,029 Answers
  • Posted on Mar 30, 2016
Pieter Vleeshouwers
Panasonic Master
Level 3:
Answers
2029
Questions
0
Helped
4113890
Points
7389
And there is nothing to read about it in the manual ?
Maybe its only an obvious problem that the lamp/ bulb is damaged ?
1helpful
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
11helpful
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
1helpful
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
jahting
2answers
Lamp replacement
Hi there
There is normally a sequence of buttons on the Projector that needs to be pressed ! What make and model do you have ?
4helpful
2answers
PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
3helpful
2answers
Panasonic LCD Projector PT-L720V
Press 'menu' and 'enter' buttons at the same time.
2answers
Panasonic PT-L759U
With the power on and the lamp off, hold the input button down on the projector then press and hold the power button for 5 seconds
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
