Your printer probably needs the Thai fonts you are using. You don't need to pay anyone to get this fixed. Just make sure your document includes the fonts when it sends the file to the printer.
Try to turn off the email scanning of your Antivirus. You may have to change the email server information over to the one that is in Belgium. Looks like your computer is still trying to use the one from Schweiz.
If the error can be reproduced, use the following sections of this document:
Product-specific documentsProduct specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html. Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
Clearing the error
Validating the firmware
Stack Trace Random error troubleshooting
Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate errorIf the error cannot be eliminated by a power-cycle, use the following sections of this document.
Clearing the error
Hardware
Feature-specific errorThe error has been narrowed down to a specific feature.
Software, Sending, Faxing, and environmental troubleshooting
The issue is typically caused if the printer is either not configured
correctly, or your system tries to send an erroneous command to it. This
error will typically show when you try and print a document /
spreadsheet or another piece of data from your system, and will stop the
print-out from proceeding. In order to fix this, it's advisable that
you follow the steps outlined in this tutorial.
Look in you menus. Your log print out is probably set to on and set to print out way to frequently. You can turn that feature off. You can go to Xerox.com, click on Support and drivers. In the search box type in 116 then go to support and then type in Log, There should be an answer there as to how to shut off log printing. You cold also type in code 19 when you get to the support page.
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution Press the On button to turn the printer off. Unplug the power cord from the back of the printer. Remove all the ink cartridges. Wait two minutes. Plug the power cord into the back of the printer. Press the On button to turn the printer on. Install the ink cartridges when prompted. If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
