Haier XQBM22-C Top Load Washer Logo
Posted on Jul 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When tub filling, it drains out at the same time.
When water is filling the tub, the water is also draining out the washer hose. As a result the tub never fills. I live in New Jersey, USA.
Anonymous
Level 3:
Brigadier General:
  • Master 4,088 Answers
  • Posted on Jul 16, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4088
Questions
0
Helped
1512393
Points
12435
The outlet of the drain hose must be higher than the water level inside the tub--normally the pump inside removes the water when needed. Get a plumber to install a proper height drain pipe for you.
F 20 displaying on front load machine
The F20 error deals with the water coming into the tub. The F20 code indicates the control didn't see any water enter the tub.
You say water comes in and fills up to the bottom of the door before the error appears.
There is a flow meter that tells the control water is coming into the washer. If the flow meter is faulty the error usually happens quickly.
There is a pressure switch and the clear plastic hose may be kinked or even have a small hole in it. One thing to try is to remove the top of the washer and then pull the hose off the pressure switch and blow through it towards the tub to check for obstructions in the air dome.
The drain hose should not be stuck down the standpipe to far. If the drain hose is stuck down the standpipe a siphon action ca occur. This means the water would fill and drain at the same time which might lead to the F20 error.
Check the drain line first and then remove the top of the washer to access the pressure switch and pressure hose. With the washer empty remove the hose from the pressure switch located on the right side of the washer and blow through it to clear any debris blocking the pressure hose or air trap.
Post the results along with your complete model number.
2answers
Using for the first time and won't work
Hello Loulan,
This is a pretty common problem and the solution is quite simple. It’s caused by the drain hose siphoning water out of the washer tub. There are two common causes for siphoning and I’ll explain both of them below.
One cause for siphoning is simply that the drain hose discharge is below the fill level of the washer tub. This picture shows the minimum drain height needed to avoid siphoning.
Another common cause for siphoning is not having an air break between the drain hose and the drain stand pipe. Usually, this isn’t a problem since the drain hose diameter is usually much smaller than the diameter of the drain stand pipe. But sometimes folks will inadvertently remove the air break by duct taping the drain hose to the stand pipe. They might do this because the drain hose keeps popping out of the stand pipe when the washer pumps out the tub. Other times, the drain hose might fit into the stand pipe with a tight interference fit.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
1helpful
Washer will not hold water
You need to check drain hose, the drain hose needs to be above the tub. If it isn't the water will just drain out when you fill
Keeps filling with water, but draining at the same time!
be sure your drain is nearly to the top of the washer if it is you may need to try a siphon break
1helpful
Washer will only fill halfway
hello, 1 possable problem a pretty common problem and the solution is blindingly simple. It’s caused by the drain hose siphoning water out of the washer tub. There are two common causes for siphoning and I’ll explain both of them below.
drain-min.jpgOne cause for siphoning is simply that the drain hose discharge is below the fill level of the washer tub. This picture shows the minimum drain height needed to avoid siphoning.
Another common cause for siphoning is not having an air break between the drain hose and the drain stand pipe. Usually, this isn’t a problem since the drain hose diameter is usually much smaller than the diameter of the drain stand pipe. But sometimes folks will inadvertently remove the air break by duct taping the drain hose to the stand pipe. They might do this because the drain hose keeps popping out of the stand pipe when the washer pumps out the tub. Other times, the drain hose might fit into the stand pipe with a tight interference fit.also check your water inlet valve filter/screen make sure its not clogged.
3helpful
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Kenmore top load washer leaks as it fills and drain hose is not an issue. There is a small hole in the plastic hosing where the two hoses meet, but why is water even getting to that point when it should be...
As the washer fills the water will go up the drain hose to the same height as the watr fills in the tub. That is why the drain needs to be higher then the tub or the water can just run down the drain.
Help!
You could have a siphoning problem. This can occur when you have your drain hose shoved down in the standpipe too far, or if there's no air gap where the drain hose enters the standpipe.
The standpipe is the drain line at the wall where your washer drain hose is placed. There should be enough air space around the drain hose to allow air to enter the drain line. Also the end of the drain hose should not be shoved so far down into the standpipe that is resting in the trap where water sits (about 4 to 6 inches is sufficient). If either of these conditions occur the washer will start to fill and then begin siphoning (or draining) water from the tub.
Do not seal the top of the standpipe either. Many consumers seal the pipe in an effort to prevent overflows or odors from escaping from the drain line. This actually causes more harm than good and results in washer drain problems.
I hope this helps you. Please post back if you have any further questions or concerns.
Top Haier Washing Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
