Panasonic Viera Th-46pz80u 46-inch 1080p Plasma Hdtv Logo
J
Jamie Papineau Posted on Mar 30, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you take the pedestal stand off? - Panasonic Viera Th-46pz80u 46-inch 1080p Plasma Hdtv
Level 3:
Top Expert:
  • Panasonic Master 76,851 Answers
  • Posted on Mar 30, 2016
Panasonic Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986350
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Disassemble procedure to many popular devices are given with illustrations.
2helpful
I would like to remove the pedestal or stand from a LG 42LG70 TV because I want to place the TV on a wall mount.
Usually the safe way to do this is look first at the owner manual but lay set face down on a padded surface so all weight is on the frame around the screen and no weight on the screen itself, exert no downward pressure in that position or screen may be damaged.
Usually pedestal is secured by 4 or more screws that may require the back cover of the set to be removed first, to get at---a careful look with it face down will show if part of the pedestal is under the rear cover of the set or not.
1helpful
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn [email protected]
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
28helpful
2answers
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Note: Extreme care should always be used when removing
without tools.
3) Remove the four screws shown in the diagram below. This will
4) Once you have removed all four screws holding the pedestal
sliding the pedestal stand away from the TV.
Where can i find a stand
If you're referring to the original pedestal base sold with the TV, your best bet would be Ebay
or Craigslist.
On Ebay, search in the Category: Electronics > A/V Accessories & Cables > Mounts & Brackets >
using the search string "vizio 50 pedestal stand" or "vizio pedestal stand base" and you should get a few matches. For example, this used pedestal stand, which has a current bid of $9.99 USD, or this new pedestal stand, being sold for $149.99 USD or Best Offer.
Hope this helps!
I need a pedestal stand for an LG 47" FULL HD,
Tries websites like Amazon.com,Ebay.com to buy an a used or new LG pedestal stand.
3helpful
Can't remove the base/feet - i want to mount on the wall. if there are screws, we can't find them - tried allen wrench, phillips, etc., no luck. thank you
See page 5 of the owner manual:
without tools.
http://www.tacp.toshiba.com/tacpassets-images/models/47HL167/docs/47HL167_om_e.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
4helpful
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
2)Remove the jack pack cover on the back of the TV to expose
without tools.
3)Remove the five screws shown in the diagram below. This will
4)Once you have removed all five screws holding the pedestal
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
4helpful
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
2helpful
Question on toshiba tv - fixya post
Found this on the www.Toshiba.com website. Q. How do you remove the stand?
Models: 26HL37, 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL167, 42HL67,
47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00078
1. Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface. NOTE: Extreme care should always be used when removing the pedestal
2. Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can
3. Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4. Once you have removed the five screws holding the pedestal stand in place, remove the stand from the TV by
sliding the stand away from the TV. The Toshiba customer service number is 1-800-631-3811. Hope this helps you with your problem.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
