New switch for the passenger side. The drivers side switch may be wired through the passengers side switch witch will make it not work if the passengers side switch is bad. Just a thought. Hope this helps.
Need to get a wiring diagram. Buy a book and follow the wiring schematic. It should help you out majorly. Can't really work on electrical issues without one.
It sounds like it could be the window solenoid, or the window motor. It's unlikely the switches on both doors are bad. Check the solenoids and motors...
try going to passenger door window switch and reset it by going down and holding for extra 3to5 seconds after window is down, do same to go up, then try doing it with master switch don forget to hold it longer, this is a reset also used on Scion vehicles, hope it helps.
Good luck
If you have a multimeter you can go to the underside of the master panel in the drivers door and independently check the switches for voltage or with no power to the switch assembly check for continuity. Good place to start. If you get continuity to through the switch then you need to check power to the window actuators in the doors.
Before you replace anything, inspect the connector pins in both the driver's door switch and the passenger door switch. If you don't find any problem with these connector pins, replace the driver's door control switch.
