Dell E173FP 17" LCD Monitor Logo
Jose Moran Posted on Mar 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I decrease brightness and contrast? - Dell E173FP 17" LCD Monitor
guruaid_cs
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Dell Master 906 Answers
  • Posted on Mar 30, 2016
guruaid_cs
Dell Master
Level 3:
Renaissance:
Answers
906
Questions
0
Helped
153262
Points
2073
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
I want to decrease brightness in LG Flatron E1600
Every monitor I have ever seen has buttons on the lower front edge that will allow you to access various menus.
Choose the right one and both brightness and contrast can be set.
Some have a button to access the menu offering choices, others may have individual buttons for these functions.
1helpful
How to adjust contrast on dell 610
From this web site:
http://www.computerhope.com/issues/ch000594.htm
How do I adjust my brightness or contrast on my laptop? Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
Other examples also shown in the above picture include pressing Fn and F1 and F2 or F7 and F8 to increase and decrease the brightness. If none of the above examples resemble your keyboard look for keys on the keyboard that have pictures of a sun or a half moon to identify the correct key to adjust the brightness.
How can I adjust the laptop contrast? Laptops only allow users to adjust the brightness of their screen. Contrast settings are not adjustable on a laptop display.
How do I save the new adjusted settings? After adjusting your laptops brightness it will retain the new settings.
Laptop brightness is still not enough or screen is black If after following the above steps your brightness is still not enough, plug your laptop into the wall to make sure it is not a power setting that is decreasing the brightness. If the laptop is plugged in but still is not bright enough, try the suggestions on the below link.
How to make the images darker
Push the 'OSD' ("On Screen Display") button on the bottom-edge of the monitor.
Use the LEFT/RIGHT buttons to select BRIGHTNESS or CONTRAST.
Use the OK button to choose that selection.
Use the LEFT/RIGHT buttons to decrease/increase the BRIGHTNESS.
Use the OK button to confirm the setting.
Use the LEFT/RIGHT buttons to select CONTRAST.
Use the LEFT/RIGHT buttons to decrease/increase the CONTRAST.
Push the 'OSD' button to exit from the OSD.
1helpful
Brightness/contrast
You can try both of this steps:
1. Press and hold the Fn key and press either arrow up or down to increase or decrease the brightness.
2. Restart the computer and tap F2 key 5-10 times during the dell logo splash screen to go to BIOS information. select video by pressing the arrow down key, then press enter. select either Brightness or Brighness AC then press enter, then select the brightness that you desired.
How do I adjust the brightness? It's too much?
By following these steps u can adjust the brightness
Step 1
Press "Menu" on your LCD's display panel (usually below the screen). Various display options will be shown on the screen.
Step 2
Select brightness from the options. This is usually indicated by a sun. Use the "+" and "-" buttons on your display panel to increase or decrease brightness.
Step 3
Select contrast from the options. This is usually indicated by an oval half black and half white. Use the "+" and "-" buttons on your display panel to increase or decrease contrast.
Thank you
1helpful
Monitor Contrast and Brightness Problem
service your monitor your monitors cadr is problem
Brightness and contrast decreased automatically
check that you were not running any programs that you have allowed to automatically change settings, enter control panel and set settings to allow manual changes only!
My contrast and my brightness is very dark on my laptop and i can't see anything. How do i make it bright again?
Most laptops adjust brightness and contrast using the function key. Pressing and holding the function key ("Fn") and press the up or down arrow keys to increase and decrease the brightness. You can determine the keys brightness or contrast by looking for keys on the keyboard that have pictures of a sun or a half moon.
2answers
More Brightness
on the front of the monitor there are key buttons naming menu, ok button and left & right arrow marks buttons first press menu button then go to brightness then by using arrow keys you can increase & decrease the brightness once you are finished decreasing r increasing press ok button.& there are many other settings you can change like contrast etc....
2answers
Screen display
It's hard to find a Compaq manual their site, but they indicate you'll find this in the help files on your computer.
This is usually done with a combination of keys-look for the Fn key and a key that looks like a sun symbol. It may have an arrow pointing up or down. Use these keys together to change the brightness.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
