Need to replace on off sw cant remove front right hand side of fasia panel
Hi dear. Open the door. There should be 1 or 3 10mm bolts around door gasket remove them. Where soap dispenser Top LHS 3 T10 screws,remove them. Open Bottom LHS pin trap.Remove the drain hose from the cover and right underneath it, there is a clip. You need to push it down to open front panel from left to right. Then you can access it. Thanks.
SOURCE: bosch washing machine
i am recently retired appliance engineer of 20 years, the rear door seal clamp is generally nowadays a large thin spring that is slightly hidden by the concrete weights at the front of the drum, if thats the case the door seal will just come off with a good firm pull round the drum edge, fitting as a reverse of removal, place the door seal in the groove so it fits like it should, then stretch the spring and fit that into the outer groove round the lip of the door seal at the drum end, once that is done fit the seal on the front panel lip, then replace that clamp, check all is fitted securely before running machine its one of those jobs that hard to explain how to do it, hope i have helped a bit, its easier to work through the front door opening than from above? if i have please rate me thank you
SOURCE: removing front panel on maytag washer
some maytag panel just pull off from the bottom,they are just a tight fit.and some have screws under the hob.
SOURCE: whirlpool duet washer model GHW9400PWO
Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left
side of the Central Control Unit and release it from the wiring harness
brackets on the right side of the washer top
Remove the detergent dispenser drawer by pressing down on the release
tab at the back of the drawer and pulling it completely out of the
washer.
Once the drawer is removed, remove the screw in the recessed hole next
to the drawer opening. Release the tab securing the right side of the
console to the washer
Open the washer door and place a flat-bladed screwdriver into the slot
in the bottom center of the console. Push the console up to release
center console tab. Be sure the ribbon cable clears the cabinet frame.
Removing the Touch Pad/LED Assembly from the Console
The Touch Pad/LED Assembly is removed as a single unit and contains the
Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
SOURCE: removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
SOURCE: how to remove front kick panel on whirlpool duet washer
just pull out the bottom it will un hook,,
I am a retired domestic appliance engineer ex Hoover. Comet .Belling Glen Dimplex. 48 years experience.
