Hi Jimmy,
/the code indicates a brake solenoid fault, check the wiring to the right and left motor connections especially the brake wires. they may have been damaged in some way. Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
SOURCE: have jazzy select series need to know flashing Code #9
Consult your owners manual for the flash code guide. I believe that you probably have a PG Drives Joysitck/Controller, in which case a 9 code would indicate problem with the brake system. Check the free-wheel levers by placing them in the neutral position, and then firmly placing them back in drive. Try to restart. If still flashing, you need to remove the seat and the shroud and examine the connections inside the base of the chair. The brakes are at the end of the motor, and there are thin wires coming from them back to the controller box. Inspect these wires for any damage, and follow them back to make sure any connections on the way are tight, and that the connections for all clip connections are tight.
The brake is electrically operated by a solenoid. If the solenoid has gone bad, then this will also cause a fault code. Contact your dealer for servicing this part. Good Luck.
SOURCE: Jazzy Power select 7
Put the chair in free wheel mode and then back again and then turn the chair off then on again. Sometimes the chair will get out of gear just a littel.
SOURCE: jazzy select contol panel all leds flash 9 times,
Bob on each brake at the motor there is a micro switch that the controller gets connection info as to wether or not the chair is in freewheel. I have seen these switches break and therefore the controller thinks the chair is in freewheel. you could also have a bad brake solenoid that is not activating the brake when you try to move. I think the micro might be the problem because you say it flashes 9 times as soon as you turn it on. You can get just the brake assembly from Pride instead of buying the whole motor/gearbox assembly. You didn't say if you bought the chair or Medicare. If Medicare did then they will pay for most of the repair you can contact your provider or a repair service Repair Xpress @1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
SOURCE: My Jazzy select wheelchair does not run
According to the troubleshooting sheet, the parking brakes have a bad connection.
"9 Flashes:
The park brakes have a bad connection. Check the left and right motor connections and
wiring.
Check to make sure that the power chair is
not in freewheel mode."
Pride Mobility Troubleshooting Sheets
