Frigidaire FASE7073LW Affinity 7.0 cu ft Electric Dryer Logo
L
Louie Longoria Posted on Mar 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced heating element now I get error E61, I ohmed out the thermostat on top of heating element seem to be ok
  • Official Brand Answer 2,267 Answers
  • Posted on Apr 11, 2016
Fixya Pro
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289809
Points
2557
Hello Louie, I appreciate your inquiry!
Based off the information you have provided your Frigidaire dryer is displaying an error code of "E61" after you have replaced the element. An "E61" error code means that there could be an issue with your heater relay or main control board. You may need to seek additional assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Tumble Dryer AEG T65270AC isn't heating up
thermal cutout switch usually attached next to the element (little round thing riveted either side)
Sep 25, 2017 • AEG Dryers
Not heating, no fault codes, everything seems normal. Checked heat exchanger ok, flow switches ok, thermal reset ok just no power to the ceramic heating elements please help me ;-(
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Apr 28, 2015 • Dryers
Over heats and shuts off
The top thermostat controls your water heater meaning if it is not working you wont have any hot water. If the top t-stat needs to be reset by pushing button in then check the element with POWER OFF and remove wires from element. check ohms should be around 12 to 19 ohms. If ok then reconnect wires and check amps. turn on power and use clamp on meter for amps. 15 to 20 amps should be ok. if not drain heater and pull out element. while you are at it drain all the water and pull lower element. if replaced and you have some hot water then quickly cool or cold then you have a broken dip tube located under the cold side of the supply line. they are cheap and easy to replace. I hope this helps.
We have a ceramic top electric Frigidaire model GLEF378CCS. Neither the broil or bake elements work in the oven. Stovetop elements are fine.
check all wiring connections, if ok ohm out oven thermostat, if thermostat ok, ohm out oven elements and if ok, check voltage at oven elements. isolate problem.
Geno, Thanks for the reply. Ironically I found the website this afternoon that you sent me links to later. Thanks for your kindness. If I get someone else the problem is continuity test on both...
Hi Tom,
I'm not Geno-- But maybe I can pick up where he left off?
First you say you did a continuity test on the heater elements-- What was the Ohms on each?
Now to the Voltage measurements:
You say you have voltage to the upper-- but not the lower--
That is normal on a cold tank-- That way you can get HOT water faster, that waiting for the whole tank to heat (as from the bottom element-- Make sense?
Until we know if the elements are OK-- the voltage checks are a bit pre-mature.
So-- With power shut OFF, and the wires lifted from the heating elements,
What are the ohms across the heater elements themselves?
(It should be low-- in the 3 or 4 ohms?-- but NOT OPEN! (which is infinity..)
What do you get?
Mack B
1helpful
Heating element replaced. Worked one load and back or dryer seemed very hot. Turned off and later ran on low. Next load no heat.
Hi.
There is either a problem with the thermostats that turn off the heating element, or the heating element is plugged (elements has contact to ground and stays always on).
Heating element and thermostats are tested reading Ohms with a multimeter set at Rx1. If the circuit is open (Ohms stay infinite), then the part is defective.
If the machine overheated, then the element may be gone again. Test reading Ohms.
Also replace the thermostats (there should be two or three of them), unless the element had a contact, the most common cause for overheating is a shorted thermostat.
1helpful
Kenmore Model 110.96585200 No heat!
You probably have a bad thermal cut-off . This is the small thermostat , located at the top of the element housing . This " thermostat " should read infinate resistance ( no resistance ) . You can put the 2 wires togather , and see if heat comes on . pt # 3399848 . Both thermostats , should read 0 resistance . They are normally closed . The thermal cut-off , will not reset itself , if open . This is a safety t-stat , for when dryer gets too hot , and will have to be replaced .
Kenmore series 70 dryer will not heat up replaced heating element thermostats check ok with ohm meter
If heating element was replaced and still no heat, Then what I would do is test the voltage current in the wiring and see if there is actually power to the element.
All parts to make dryer heat are:
heating element
thermal fuse
thermostat
timer
any one of these units can be faulty
Hotpoint ctd00G will not heat up
This is most likely the thermostat switch or possibly the heating element itself.
One or the other is likely needing replacement.
If you are competent at electrical repairs, and have a test meter; Unplug and move to allow access.
Undo rear top screws and remove lid.
Heating element is usualy on top. Disconnect leads and check continuity of switches and element.
Replace switches with similar if either are open circuit. Available as spares from online parts centres.
Heating element should read in the low Ohms - around 20 - 35 Ohms if Ok, otherwise replace.
ONLY ATTEMPT REPAIRS IF COMPETENT (I have to say that)
Sep 23, 2009 • Dryers
2answers
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
