I have found a manual that may be better than you have now, it seems real easy to understand and has pictures too,basically you use the Volume + & - keys to step through the Menu, and there is an "Auto Search" function too..5.5.1.1 page 11, start there and follow pictures.. START: Press MENU Key to enter the menu list, press Left and Right Key to
enter the following list, press Up and Down Key to enter the sub-list
and then press Left and Right Key to setup the contents. 5.5.1.2. In the CATV state, choose Auto scan and press OK
to enter Cable system settings. Four options, AUTO, STD,
IRC, HRC can be chosen.
5.5.2. In the Start to scan item, press VOL+ to start searching.
Auto searching will clear the primary program.
5.5.3. Press Auto Scan Add Ch will start auto search based
on primary program.
You don't need to do all the extra bits like names etc, if you don't want... just use default settings..
Get the manual below...
http://www.curtisint.com/html/CustService/Manuals/CUR_KCR2614A_EN.PDF
