Roadmaster VR3 VRBCS300W Wireless BackUp Camera with 25 LCD Monitor Logo
i
ivan b Posted on Mar 24, 2016
Can you use this as just a regular mounted dash cam? i want to install it on my moped can you attach it to a 12 volt battery or does it have to be wired to the back up light wires
1helpful
2answers
My dash lights get dim sometimes then will go back bright after a while, could it be a fuse?
The dash/interior grounds are behind the side kick panels on each side of the car. You may have 1 or 2 ground points mounted on the steering column. Also check the battery to body ground. Also check the voltage at the battery when the vehicle is running. Battery voltage is usually 12 to 12.5 volts. When running the alternator should put out 13 to 14.5 volts.
I have a 1996 palomino tent trailer. I came with two older 12 volt batteries and has two battery mount brackets. Is it supposed to take 12 volts or 6 volts. Also do I need both batteries to run...
It depends.
On some models, one battery handles the fridge and heavy loads, while the second battery is for lights. On models that came with one battery, owners have installed a second for longer camping trips. And some owners have switched from one 12vt to two 6vt golf cart batteries for longer power.
2answers
Electrical
Replace the battery.
I needed to replace climate control unit on1997 Grand Am GT. Concerned with how to remove the cluster face panel w/o breaking it.
Let me know if this helps out.
Heater & Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the screws securing the cluster trim plate to the instrument panel.
  3. Tilt the top of the cluster trim plate downward releasing the clips that mount the bottom of the trim plate to the dash. Remove the trim plate.
  4. Remove the screws attaching the accessory trim center plate to the dash.
  5. Tilt the top of accessory trim plate downward releasing the clips that mount the bottom of the plate to the instrument panel. Remove the plate.
  6. Remove the screws attaching the control assembly to the dash.
  7. Remove the control assembly from the dash.
  8. Disconnect the control assembly electrical connectors.
  9. Remove the control assembly.
To install:
  1. Install the control assembly.
  2. Connect the control assembly electrical connectors.
  3. Install the control assembly attaching screws.
  4. Push the mounting clips into place and roll the top of the accessory trim plate upward into position.
  5. Install the screws attaching the accessory trim plate to the dash.
  6. Push the mounting clips into place and roll the top of the cluster trim plate upward into position.
  7. Install the screws attaching the cluster trim plate to the instrument panel.
  8. Connect the negative battery cable.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 40; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
2helpful
2answers
I need to put a crankshaft sensor but I don't Know its location I already changed the cam sensor. Ronnie
The crank sensor is located on the engine near the flywheel axis of the crankshaft.
Crankshaft Position Sensor Removal & Installation To Remove:
Location of the crankshaft position sensor on the 3.3L and 3.8L engines 91154g21.gif
NOTE: On the 2.4L engine, the crankshaft position sensor is mounted to the engine block behind the alternator, just above the oil filter. On the 3.0L, 3.3L and 3.8L engines, the crankshaft position sensor is mounted on the transaxle housing, above the vehicle speed sensor.
  2. Raise and safely support the vehicle.
  3. Disconnect the crankshaft position sensor electrical connector.
  4. Unfasten the sensor mounting screw, then remove the sensor from the vehicle by pulling it straight out.
To Install:
NOTE: If the sensor removed is going to be re-installed, clean off the old spacer on the sensor face. A new spacer must be attached to the sensor face before installation. If the sensor is being replaced, be sure that a paper spacer is attached to the sensor face.
  1. Install sensor and push the sensor in until contact is made. While holding the sensor in this position, install and tighten the mounting bolt to 105 in. lbs. (12 Nm).
  2. Connect the crankshaft position sensor electrical connector.
  3. Lower the vehicle.
  4. Connect the negative battery cable.
4helpful
How do i install a 12 volt air horn to my 2ooo Celica GTS
Finding the room to mount it is the hardest part depending on the type you buy. You will need to test fit it into a few different positions until you find the right spot. Best not to point them into areas they will get wet or too much air pushing into them. They can be mounted in pretty much any direction.
The easier way is if you eliminate your original horn, and hook the 12 Volt power supply from the original horn, to the Air pump that will come with your horns, or that is attached to the horn. If you have to extend the connecting wire, make sure you have a secure connection at both ends
To have both horns, you'll need to install a special switch from the interior to a Heavy Duty 12 Volt relay in the engine compartment that you install, the relay will need to have amperage high enough to match the horns requirements, then connect it through a "Fused" circuit from the battery.
They usually put those instructions on the package.
That's it. You press the horn switch, it energizes the pump & instantly provides an air horn sound.
good luck
I need to find out the weiring diagrame to install it
Equalizers Like a crossover, the equalizer gets installed between your receiver and your amplifier. The outputs will be preamp connections to your amplifier. You'll find EQs that are designed to be installed in the dash, above or below your receiver. Others are designed to be mounted in a remote location, like the trunk. Either way, the wiring connections required will be the same. To install:
1. Mounting the equalizer:
A remote-mount EQ can be securely mounted with just a few screws. Anywhere between the receiver and the amp is fine. Most people mount the EQ in the trunk near their amp, especially if you have more than one amp. This also makes it easier to add additional amps later. You should mount it where it will be easy to get to so that you can make adjustments without too much trouble. Don't mount your EQ directly on steel — you will invite noise problems. Instead, install it on a non-conductive board and attach the board to the car body (or use rubber grommets under the screws to isolate the crossover).
An in-dash EQ can be mounted above or below your in-dash receiver, assuming that you have space available in the dash. This will require custom installation work. Another option is installation below your dash, in a universal under-dash mounting kit. To install the under-dash mounting kit, attach it to the mounting surface using the supplied self-tapping screws. In most cases, the use of an under-dash kit will require modifications to the kit or to the mounting surface.
3a-xover.jpg Locate the remote turn-on lead behind your radio (usually a blue wire). 3b-xover.jpg Connect the turn-on lead from your amplifier wiring kit to the blue wire. You can wrap the bare wire ends together and cover with electrical tape, or use solder. 2. Making the power connections:Your EQ will require 12-volt power, ground, and turn-on signal connections.
  • To obtain 12-volt power: Cut a length of small-gauge cable (16 gauge is typically sufficient) long enough to reach from the EQ location to your vehicle's fuse panel. Strip one end of the wire, and attach it to the EQ's power input. This may require a crimp-on connector, or bare wire might be sufficient, depending on the equipment you're installing. Route the wire from the EQ location to your car's fuse panel. Using a fuse tap, connect the wire to a source of switched 12V power.
  • To ground the EQ: Remove a bolt near the EQ mounting location. Crimp a ring terminal to one end of a length of small-gauge wire, and then bolt the terminal tightly to the vehicle's metal chassis. Scrape away any paint and clean the bolt location thoroughly. If you can't find a convenient ground screw or bolt, drill a hole for one — be careful not to drill into the gas tank or a gas or brake line.
  • Making the turn-on connection: In most cases, you can tap into your in-dash receiver's amp turn-on lead to get a turn-on signal for your EQ. Remove the receiver from the dash to access the turn-on wire (usually a blue wire). For step-by-step instructions on removing your vehicle's radio, see your vehicle-specific Crutchfield MasterSheet™, or read our In-Dash Receiver Installation Guide. Strip the insulation off a small section of this wire coming from the radio. Strip the insulation off another small-gauge cable that's long enough to reach from the in-dash receiver to the EQ, then connect the two with crimp caps or solder. Wrap the solder or crimp connection with electrical tape to guard against a short. Using wire ties to secure the wire, route the turn-on lead behind your dash all the way to the EQ mounting location.
3. Making the signal connections:
In most cases, you'll be routing RCA cables from your in-dash receiver's preamp outputs to the inputs of your EQ. While your receiver is out of the dash to access the turn on lead, connect a set of RCA patch cables (long enough to reach your crossover in its mounting location) to these outputs, taping them together so they won't come apart. Route the patch cables (again using wire ties) behind the dash, and to the crossover mounting location.
3helpful
Cant find cam sensor in 2004 dodge stratus r/t
2.0L 2.4L it is on The BACK OF the Cylinder Head REMOVAL
The camshaft position sensor is mounted to the rear of the cylinder head.
  1. Remove the negative battery cable.
  2. Disconnect the PCV hose and reposition.
    1. Disconnect electrical connectors from the camshaft position sensor.
    2. Remove camshaft position sensor mounting screws. Remove sensor.
      1. Loosen screw attaching target magnet to rear of camshaft and remove magnet.
      INSTALLATION
      The target magnet has locating dowels that fit into machined locating holes in the end of the camshaft.
      1. Install target magnet in end of camshaft. Tighten mounting screw to 3 Nm (30 in. lbs.) torque. Over torqueing could cause cracks in magnet. If magnet cracks replace it.
      2. Install camshaft position sensor. Tighten sensor mounting screws to 12.9 Nm (115 in. lbs.) torque.
      3. Carefully attach electrical connector to camshaft position sensor. Installation at an angle may damage the sensor pins.
      4. Connect the PCV Valve hose.
      5. Connect the negative battery cable.
2.7L V6
REMOVAL
The camshaft position sensor is mounted in the front of the head.
  1. Disconnect electrical connector from sensor.
  2. Remove camshaft position sensor screw.
CAM Sensor Location 2.7L
  1. Without pulling on the connector, pull the sensor out of the chain case cover.
INSTALLATION
  1. Install sensor in the chain case cover and push sensor in until contact is made with the boss on the head. While holding the sensor in this position,install and tighten the retaining bolt to 12 Nm (105 in. lbs.) torque.
  2. Attach electrical connector to sensor.
Top Roadmaster Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Roadmaster Home Security Expert? Answer questions, earn points and help others
