Computers & Internet Logo
Erika Whitmore Posted on Mar 24, 2016
Language is in Swedish i need English - CyberLink YouCam
I speak English, but Facebook is in Swedish.
click on settings from drop down
you can change your language preference under the section general
I have a Samsung sync master 943 bwx and when i first set it up my main menus was in some other language how do i get it back to english?
I have tried to find a manual, to see if there is a way to change it, but have not been sucessful.
The languages it supports are: French , Spanish , English , Swedish , Turkish , Italian , Portuguese , Russian , German so it's possible to use google translate to find out which is the option for language.
I know Spanish is Idioma, Swedish is
eitherS PR?K or TUNGOM?, Turkish is dil.
See if you can find that option, and you will probably find "English" or "Ingles" as a sub-option.
Can i have the service for free to change my phone setting from swedish to English
Settings >> General >> International >> Language >> Svenska. and done changes it to swedish and
Installingar >> Allmant >> Internationellt >> Spark >> English. Klar at the the top right will change it to english
thats for the Iphone
Feb 22, 2011 • iPhone Apps
1helpful
2answers
I want to change laguage from Swedish to English.
The customer cannot go to setup menu because he won't be able to read it - it's in Swedish
This is what I need you to do.
Press the menu button (base everything on symbols/icons) - You would see a menu in swedish but on top are tabs. The rightmost tab is a camera with a ranch symbol - so move the joystick to the rightmost tab. Scroll down to the option with a BUBLLE SYMBOL with ABC on it, press in the joystick (toggle switch) to enter or select and scroll down look for ENGLISH.
1helpful
Need to change language to English
Hi. Here: (http://www.htc.com/www/supportdownloadlist.aspx?p_id=133&act=sd&cat=2) you can find the original WWE ROMs for Touch Diamond (in English). You can flash your device (reinstall the Operating System) with one of these ROMs by following the instructions. Hope this helps.
Language preference is in swedish, and want to change to english.
last page (8 of 8) upper left hand box is language... Then the second language down is English.
Go to the web page below, set the translation from Swedish to English and type in the options that you see on each page.
http://freetranslation.paralink.com/
You should then be able to work out which option you need to reset the language to English.
It might take a bit of time but you will get there.
HTH
Peter
PROBLEM
open control panel /click regional language/select your language and enter.
9helpful
2answers
Change Language Setting on W375
Hello there. please do the following. press the menu button>press the screwdriver option>press the wrench with a brown file icon>go down 6 places from the top and select it> you will then see english at the bottom. hope i helped!
Top CyberLink Computers & Internet Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
