Question about Roland VersaCAMM VP-540i
I have a roland sp-540v, trying to print on banner material with black backing. Keeps on getting message to setup sheet while everything is loaded correct. The sensor is probably not picking up black.
  • Roland Master
  • 1,682 Answers
Could you try
(1) Temporarily stick a white strip over the sensor where it detects the media or
(2) On the length of the media or
(3) Even staple same sized white media below the black one which you can un-staple after printing.
kindly ignore if these are (s) tupid answers
Posted on Mar 23, 2016
SOURCE:
Distorted printingting
hello
try to clean the Encoder strip of your sp540, gently with alchool isoprophilic
i add a video explaining (the procedure and the result is the same for sp540) i hope this is helpfull. good luck
Feb 04, 2014 | Roland VersaCAMM SP-540V
Continuosly getting pinch roll error (invalid right position) on Roland versacamm sp-540v
if the problem is persists you have to replace the data cable connected to the head ( this cable goes foward and backward with the movement of the heads and sometimes it brokes ) i had the same problem and the solution is this.
Jan 31, 2014 | Roland VersaCAMM SP-540V
I have roland verscamm sp-540v when i switch on then error comes service call 0101
the 0101 error in sp540 is the Limit Position Initialize has not been done. you find videos on you tube that can help you to do the limit position operation. (you have to enter in Service Mode Menu) its easy to do it yourself. i hope this help.
Dec 24, 2013 | Roland VersaCAMM SP-540V
I need a driver for Roland VersaCAMM SP-540V for windows 7
IF I CAN REMEMBWE YOU CAN DOWNLOAD IT FROM THE ROLAND SITE
Nov 17, 2013 | Roland VersaCAMM SP-540V
I have roland verscamm 540v when i sub switch on
hello m f azam
have u solve the problem already?
Aug 20, 2013 | Roland VersaCAMM SP-540V
Sum error roland vp 540
hello, je viens de remplacerla carte m?re de mon Roland sp-540v et la machine ? l allumage m affiche sum error, aidez moi ? r?soudre cet error
Mar 18, 2013 | Office Equipment & Supplies
I need drivers windowS 7 for Roland VersaCAMM SP-540V
hello
i add a video explaining how to install sp540v in win7
u need to install the Intercon-NetTool (that u can download from the Roland website) to allow the comunication with the plotter. its all well explained in the video. good luck
Feb 27, 2013 | Roland VersaCAMM SP-540V
SETUP SHEET PINCHROLL ERROR INVALID IF RIGHTPOS
i had a similar problem with my sp540 and the solution was the strip (the electrical one, that is connected to the head, broked)
have to be replaced. and everything goes ok .good luck
Jan 15, 2013 | Roland VersaCAMM SP-540V
I have a Roland SP-540V printer and I keep getting pinch roller errors. I have cleaned the iris/sensors, hard restart, rebooted my system. Still is not recognizing the print media. I printed yesterday no...
hi have had the same problem, you need to clean the data strip that is connected to the main cutting head .its a clear looking plastic strip between 2 other strips you can't pull it all the way out so be careful. just wipe it with a clean cloth you will see black soot like powder come off it, as soon as you do this it should be back to normal, repeat weekly and you should be ok.
Feb 25, 2010 | Office Equipment & Supplies
Roland VersaCAMM VP-540i Logo
217 people viewed this question
Top Roland Office Equipment & Supplies Experts
JonSnell Electronic
JonSnell Electronic
Ravi
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
