This is the procedures on how to Factory Reset spice m351: First unlock your phone, But as what you said you can`t unlock it because it protected by a password. I might suggest to you use this material that can unlock your phone it is Volcano box which have a features to unlock UserCode of a mobile phone. this is the reference: "http://www.volcano-box.com/features.html" for more information about Volcano Box Tool. Then watch this video, it will guide you on how to use Volcano Tool : ==[LINK VISIBLE TO REGISTERED USERS - CLICK HERE TO SEE THIS LINK] You can also use this site to unlock your phone there are a several steps on how to easily unlock your phone. This site can handle all model of phones. Here is the reference "http://www.oneunlock.com/en" 1.To use that site you can only choose the brand of your phone. 2.After you choose, select the model of the phone. 3.Select your country. 4.Choose the carrier 5.Then you will go to the process of unlocking your phone. After you unlock your phone, you can now able to factory reset your phone. First you need to turn off your phone. You will press three important key simultaneously until the recovery mode comes. The first button is Power Button, second is Volume Up Button and last is option Button. You will also use center Button. Bring your phone into recovery mode, simply press center button then go to Menu. From the menu navigate to "wipe data / recovery" using Volume button. Then do okay with option button. Use Volume button to navigate then select "Delete all your data" Now press option button to select then it will do formatting. When formatting is done, do navigate again to "wipe data/ factory reset" then choose again "delete all your data". After that reboot your mobile phone , it will takes some time around 60seconds for fast reboot. Then your phone will be the same like the first time you buy it. All data store are deleted. Reference: "[LINK VISIBLE TO REGISTERED USERS - CLICK HERE TO SEE THIS LINK]".
Read more: How can i get Symphony M82 factory reset password? - I want to know Symphony M82 factory reset password. :: Ask Me Fast at http://www.askmefast.com/How_can_i_get_Symphony_M82_factory_reset_password-qna9312144.html#q4919307
SOURCE: Open phone lock symphony m82
Hi if you've locked your phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
If you lock your phone again some time in the future and you're still with the same service provider you can use that same Puk code.. CHEERS..
