Factory reset
Proscan PLT 70330 use power and volume buttons to reset.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Factory Reset on Proscan PLT7223G or Tablet
How to reset proscan tablet model PLT7033D to factory setting its locked
want to reset my PIN on my Proscan PLT7033D
I can get to the android but the words not there on my tablet
Nakella, this is all the Info.To perform a factory reset, you need to turn it OFF first. After that, hold pressed the Volume Down and Power buttons until the Android logo appears on the screen. Then you can use Volume down and Volume up keys to navigate through the recovery menu. To reset your tablet, select the Wipe data / Factory reset option. Be advised, by doing this, you will lose all the data from the tablet.
You can also unlock your tablet by inputing a few times a wrong code until a message that ask you if you forgot your password appears. Tap on it and follow the instruction provided. By doing this, you will use your Google mail account to reset the password from your tablet. In this way, you will keep all the data that you currently have on your device.
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
