With engine off try rotating pto shaft by hand 1/2 turn , then restart it and try again
Testimonial: "I have turned it both directions and it won't turn. Sounds and acts like a pin has slipped and is stopping it. With engine running and pto engaged you can turn shaft back and when you let got it turns about 180 degrees and stops again."
I cannot get it to turn a full turn. Thanks for suggestion. Please read testimonial.
i meant turning the load or implement side , if it wont turn you'll need to see why that is , load side should allways free wheel with pto disengauged , if you have tried to engage to a stuck load im sure your sheer pin is now broken , and do try to not touch a pto shaft with engine running , ive lost a good friend a few years back that did just that !
