Tips for Choosing Good and cheap sunglasses.
<br />UV Protection<br />•Make sure the sunglasses you choose will block at least 99 percent of the sun's ultraviolet (UV) rays. UV-blocking glasses protect the cells in your eyes from damage that can lead to cataracts or macular degeneration. If you purchase sunglasses that don't block UV rays effectively, you will be missing out on the most basic function of sunglasses: protecting your eyes. Even the cheapest plastic lenses often come with 99 percent or 100 percent UV protection, so check the label before you buy. <br />Lens Type<br />•When browsing the sunglasses rack, keep in mind that some lenses are better than others. Inexpensive sunglasses are usually fitted with plastic lenses, which come in many varieties. For driving or outdoor sports, polarized lenses are best--they block reflected light from the road, snow or water. For general-use sunglasses, grey-tinted lenses are recommended because they absorb light evenly and provide clear and comfortable viewing. <br />Frames<br />•Although you will not be paying much for your sunglasses, you will still want them to last more than a few days. Cheap sunglasses made with metal frames are often flimsy and break easily at the joints. A pair of shades with sturdy plastic frames are likely to last longer than metal-framed sunglasses. Plastic frames are also preferable because they will not rust when wet, take longer to sink if dropped in water, won't get hot if left in the sun and are easier to find at the bottom of a pool.
