Try this. Hold down wrinkle prevent and dry level and time at the same time whilst turning it on
On my model, you need to press 3 buttons to do the reset - wrinkle prevent, dry level and time
I have a DV80F5E5HVW and had to press the bottom far right button(shirt with bell symbol) together with the third from right button(shirt with clock symbol). Then the display showed "bE2". Then turned machine off and on and the HE error code was cleared and machine worked.
Does anyone know if there is a manual time setting. I've cleaned the heat exchange and moisture detector but it still stops the cycle early with damp clothes. I'd rather be able to set it for an extra 30 mins without it auto switching off so I know they are fully dry?
Clean heat exchanger, see link.
https://www.samsung.com/au/support/home-appliances/cleaning-the-heat-exchanger-on-a-samsung-dryer/
HI GUYS I HAVE PROBLEM WITH MY DRYER MODEL DV80F5E5HGW AND STILL I CAN'T ALWAYS RESET THE ERROR HE HAS ANYONE HAS ANY PROBLEM WITH IT? I TRYED DIFFERENT COMBINATIONS AND NOTHING ANY CHANGE. CAN ANYONE HELP?
Thanks a lot. You saved us!
Guys, thank you for the help. Really. Saved me lots of nerves and time.
Turn off the dryer, wait about 15 seconds, hold down Wrinkle Prevent, Dry Level and Time then press and hold down power button until you see the control panel screen show all defaults. Once the screen changes, turn off the dryer and wait 15 seconds. That cleared mine.
Yep Fixed HE error for me too after machine overfilled. So annoying that you would have to get an engineer to fix it otherwise... Mine was under warranty, but I guess overall they must make money by forcing extra service calls or they would put it in the manual...
just did this to mine brilliant fix thanks so much !!
It works. Thank you so much! :D
thank you
