Manufacturer of quality high performance mobility products including Jazzy Power Chairs Scooters Go Go Travel Mobility Products Lift Chairs and Pride Vehicle Lifts
Level 2:
According to the owner's manual for this scooter, flash code 7 indicates a speed control lever fault. This is the lever that you push to go forward and reverse. The lever is attached to a throttle potentiometer to control the speed of the scooter. The lever has to be in the middle or neutral position when the scooter is turned on, if not, you will get a 7 flash code. If the throttle potentiometer is damaged you will also get a flash code 7.
You can try to adjust the throttle pot or try manipulating the neutral position and turning the scooter on and off until the computer sees neutral. This is a potential work around and will cause the scooter to creep forward when running with hands off the throttle lever because there is no zero setting. I usually just replace the throttle potentiometer and this solves the problem. I hope this helps.
hi Nico, first of all let's check those brushes, at worse it 's the controller as i see that before...
Have you check the wiring from the throttle pot to the controller ?
One last thing , the speed pot,,short the two white wires ? and see if there is a improvement as it very hard to sometimes to find a faulty pot purely by taking resistance readings,..
Usually turning the key off and removing it then re inserting the key and turning it back on without touching the paddle levers. If that doesn't fix it then the speed pot will need to be replaced.
Yup you got a code seven failure code, speed pot malfunction . What
pots typically do is that they oxidise. This pot is a variable
rersistor that opeates between 0 - 30k ohms. When tuning the pot it
shoud ram up and down smoothly. To test for this You may also need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8 Disconnect
batteries from the scooter. Simply attach the multimeter to the pots
terminals, select correct ohms scale and watch the needle. Th needle
when turning the pot should move gracefully up to 30k down to zero as
the pot dial scooter speed increases. Failure is detected when the
needle jumps around, the oxidation causes the pot to connect
inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the
pot. The potss are not sealed so there are little holes you can spray
into. Use liberal of cleanner.
Yup you gt a code seven failure code, speed pot malfunction . What pots typically do is that they oxidise. This pt is aa variable rersistor that opeates between 0 - 30k ohms. When tuning the pot it shoud ram up and down smoothly. To test for this You may also need a VOM meter only $9 http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8 Disconnect batteries from the scooter. Simply attach the multimeter to the pots terminals, select correct ohms scale and watch the needle. Th needle when turning the pot should movee gracefully up to 30k down to zero as the pot dial scooter speed increases. Faaailure is detected when the needle jumps around, the oxidation causes the pot to connect inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the pot. The potss are not sealed so there are little holes you can spray into. Use liberal of cleanner.
Hi. If the light flashes 7 times, it has a speed controll fault. It might be the throttle lever ( wig wag ), or it might be the speed pot that controls your top speed.
Try moving the throttle lever ends up and down while you are driving the machine. Doing this wont fix it, but it will highlight the problem, if the throttle lever is faulty. Also try moving the speed pot back and forward a few times.
Good luck. Neil.
