Jura does not allow access to internal parts for cleaning. Brew group is the dirtiest part as it deals with complicated movements to make coffee.
Error 8 means the brew group is not returning to start position after it completes entire cycle to make coffee.
Jura recommends to remove drip tray. Using a thin cloth, insert the hand all the way under the machine. You will feel access to the bottom of the brew group. Wipe clean the bottom of brew group as best as you can. There will be lot of coffee powder (wet & dry) that is partially responsible to prevent brew group return to start position.
A better method is to open the machine using special key. Clean & lubricate the brew group. every two months. This will prevent Fungus and Bacteria growth. .
Instruction videos are posted on You tube channel "Parts Guru USA"
Use the link below to order the special key. Services Unlimited Inc Parts Guru Since 1988 Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
F21 Fault Code Repair LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
Hi
FH error indicates no water detected entering the
machine or pressure switch trip not detected. If after 30 seconds the control does not detect water
entering machine and then valves will be turned off and the error code will be
displayed. It can also happen if the control has turned the water valves on and
after 8 minutes the flow meter has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip, the valves will be
turned off and the error code will flash. You'll need to Press PAUSE/CANCEL twice to
clear the display. Please post a comment if you need more
help.
Thanks
Rylee
