I turn it on on the pad it says on wait and after a few minutes the flame sign comes on, then its says reset and error code 07 shows up. Thanks.
SOURCE: CEL Error Code p2227
P2227 is thrown for barometric pressure circuit range/performance error. I'm researching what causes it since I have the same thing on my turbocharged Accord.
SOURCE: error code LE
Hello and welcome,
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
SOURCE: Phaser 6360 laser failure code 07
Yeah I had a look at the website there too, try powering down again and plugging it out for a longer period of time. You need to get the whole machine to reset and loose all saved info in the bios. Also cleaning it out of all loose toner on any contacts might help!
Niallbt
SOURCE: Hotpoint WD860 - Fault Code F-07
F07 indicates heater relay stuck.
You need to check the heater to see if it is faulty, and fit new one if it is.
Please rate my solution.
Thanks.
SOURCE: What does error code 8001050F mean? Why cant I
Called Playstation Network, they are doing routein mantanice on there server. It should be back up by 9pm from what they told me but it might be later since it's 9:12
Testimonial: "Thanks for telling me I appreciate it"
