The line is barely noticeable. but at the bottom of the screen it looks like a 1/2 inch of what seems the top of the picture is there
Anything can be fixed, short of it being totally destroyed. The question is can it be fixed in a cost-effective manner? Today's TV sets are manufactured for a three-year lifespan....regardless of what the manufacturers say. They are made with minimal-tolerance components, and are designed to fail in the 2-4 year range. Most make that, some don't even get out of warranty. The manufacturers take the risk because it is more profitable for them to make some warranty repairs in order to get the repeat buyer in 3 years instead of 10. If you got 3 years out of you set you did well. Some try to repair the sets themselves; some are successful, many are not. These devices are delicate and often in the process of fixing one thing, something else gets broken. You can try for repairs, but you are most likely better off buying new, and consider this when buying.....look for features you want NOW and not in the future, since by the time those feature are needed, you will be once again in the market for a new set. One additional piece of advice; to help these new devices last longer, buy and install a UPS to protect them from voltage variations and power surges. Surge suppressors alone can help, but they don't respond to voltage variations that often occur in electrical service. These are often the killers on these devices.
SOURCE: Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
SOURCE: I have a Viera 42 inch plasma tv (model
the problem is the panel is going bad. usually not economical to repair. repair usually runs as much as a new one.
SOURCE: 4 year old vizio 42 inch tv lcd. While watching
Maybe a power supply or related issue but at 4 years of age the set has reached its life span----parts will be hard or impossible to find.
If you got four years I would retire it and recycle it and then replace it.
