Nikon Coolpix S4000 Digital Camera Logo
D
DINESH KUMAR Posted on Mar 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Digitizer is not in operational mode - Nikon Coolpix S4000 Digital Camera
abdul rauf
Level 2:
Dedicated:
Visited the website for 20 consecutive days.
  • Nikon Expert 483 Answers
  • Posted on Mar 19, 2016
abdul rauf
Nikon Expert
Level 2:
Dedicated:
Answers
483
Questions
0
Helped
95965
Points
726
Check the battery, contacts inside, the power switch etc, if these all OK, then must open the camera.
How do I change the password
1. Turn camera on and wait for the password screen.
2. Press and hold the enter button until the camera switches to the 5 digit password mode. "Trail sentury cams will not indicate a 5 digit mode on the screen, but it will show "-----".
3.Press enter to confirm 5 digit mode.
4. Enter the 5 digit code "66214, then press enter. *Note it will accept a 5th digit.*
5.Camera should display "PASS" and go into the operating mode.
From here you can program a new password from the setup mode.
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
How to operate remote control
That's up to you. The camera offers two remote modes. The quick-response remote mode fires the shutter when you press the button on the remote. The delayed remote mode gives you two seconds to hide your hand behind your back before firing the shutter.
Full details are in the "Self-Timer and Remote Modes" section of the manual (page 67 in my copy).
55helpful
Password Error
To reset the password:
Turn unit on and wait for password prompt
Depress the and hold the enter button until camera
switches into 5-digit password mode _ _ _ _ _.
Trail sentry systems will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th digit is entered in the _ _ _ _ screen.
Camera will now go into operating mode, and user can now program a new password from the setup mode
2helpful
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
17helpful
Bushnell Trail Sentry Digital Trail Camera
Dec 27, 2007 • Cameras
No image
No image in shooting mode on Canon S500. Flash operates and shutter clicks. Whats wrong?
Auto switching to video mode after still photo
Take the battery out and re load the operation. This will do a reset of the operation modes.
Zoom
Yes, you may be in either landscape mode or macro mode.
Focusing distance in macro mode
The Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
