Mitsubishi WS-55809 55" Rear Projection Television Logo
A
Anonymous Posted on Mar 17, 2016
Mitsubishi WS-55809 Blue screen on DTV and Component connectors. Think it may be the connectors on Terminal board
Plug Component cables from Cable box to DTV and get Blue screen. DVD player to Component 1 or 2 blue Screen. TV was recently put in storage for a couple of months.
  • Anonymous Mar 18, 2016
    It is old projection purchased in 2001. Picture works wit the rca composite jacks and cable jack. Picture is fine when using those inputs, just bein 480. Had convergence issue before not seeing same symptoms. Just not working with the component or dtv inputs. Hooked the cables up same way I have done for years & tried different cables to rule a bad cable
5 Related Answers
MrBob84
Robert Jones
  • 90 Answers
  • Posted on Feb 13, 2008
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Anonymous
  • 184 Answers
  • Posted on Feb 14, 2009
SOURCE: Mitsubishi WD-73732 has 1 inch blue/purple band at screen top.
Is this a DLP or LCD projector?
Anonymous
  • 87 Answers
  • Posted on Apr 12, 2009
SOURCE: wavy diagonal lines only with component cables, not hdmi
You have a bad format board which is no longer available. the DM chassis can be sent in for repair by an authorized Mitsubishi servicer Call mit at 1 800 332-2119 they might help with cost of repair have receipt and purchase date available.
nicknovikov
Nick Novikov
  • 101 Answers
  • Posted on Oct 05, 2009
SOURCE: Mitsubishi big screen Model ws-55809 shuts off after powered.
two possible problems:convergence IC(2pc),or hi voltage output:transistor,flyback,capacitors.
Anonymous
  • 29 Answers
  • Posted on Oct 09, 2009
SOURCE: My 6-year old Mitsubishi WS-65813 TV intermitantly
need resolder bottom of boards
Cable box connections
The model listed has only ONE HD input and it is on the rear and marked DTV--it is a component input with red, green, blue and a red and white for audio---cable box would have to have same outputs on its rear.
Does the Mitsubishi ws-73909 support hdcp and if not how do I get HD from my xbox360? I am currently running a hdmi cable into my hd fury3 into the dtv input and I do not have a picture.
I don't think it does since it doesn't have an HDMI input of it's own. You may be better off connecting your Xbox to the TV by component video (Red, blue, green RCA connectors with audio L/R on a separate cable).
I wish that I could be of more help.
2helpful
Mitsubishi WS-65907 rear projection TV HD goes blue.
I would look at the source for the Hd signal as being the problem--if you are using some kind of cable or sat box it will deliver the signal to the DTV input on the back of the set--this is the HD input for this set.
It is possible to have a problem like you describe be one in the set--but very unlikely----have you looked on that green signal board for any signs of Glycol?
Anything that will produce a 1080 signal to the DTV input should tell you if the problem is the set or the source of the HD signal that is causing the problem.
If you have questions or need advice let me know--I am here to help people.
if this information has helped you rate this solution as i do this here for free.
SD TECH
4helpful
2answers
Greenish picture using DTV input
If the set is normal on AV inputs or thru the coax input--but has problem in the DTV(HD) I would suspect whatever is giving it signal(it is component input) is the problem--the component input for DTV could cause this problem--red,green, blue carry not only video but chroma information---if you are using a direct TV box of some kind return it and get another---only other possible cause(Long shot) would be to do a factory reset on thisTV--All
Mitsubishi sets have an option menu which resets the whole set back to condition it was when new in the box--If you want to try this verify model number to me and I will tell you how to do it--Remember: the set is not smart enough to know which input you are using--if you have a problem only on 1 input--it usually is not the set--it usually is what is connected to that input.
If you have questions or need more help contact me by replying to this post.
I do this here for free so if this helps you take a moment and give me a vote here.
SD TECH
Mitsubishi WS-55809 Upconvert Stopped working
your problem is the 2hdw board is located in the signal board.
Connecting PS3 to Mitsubishi WS-55809
On the back of the TV you should find three sets of the component sockets, only one can produce 1080, the one that is labeled dtv (should be the one on the farthest right of the three sets).
Wanting to get my full hdtv out of this tv 55513
Are you trying to use the red/blue green component cable or HDMI cable? You may have to go into the menu on your cable box and specify which cable you want it to output to.
Dont get signal from dvd or cable box
Do the self test located here in threads or ctechnicians.com
Mitsubishi ws-55809
Looks like you are going to be working with the following:
1080i (HDTV) • 480p (EDTV) • 480i (SDTV)
Hook up depends on what else you have connected to the TV.  If you have nothing connected to the DTV component inputs, I suggest using those, as it will allow up to 1080i.  Otherwise, use the 2 other component connections directly to the left of the DTV connections.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
