Hello Robert,
I tried to pull an Owners manual for your Panasonic system...
But Panasonic North America was temp "UNAVAILABLE"
(good company procedures: mid-night maintenance)
Merely FROM MY FAMIARITY with a SIMILAR system (KXTG4771)... you should have about 19 minutes of recorded memory space.
Okay they are back... your OWNERS manual is at the bottom...
Nope... your has 17 minutes
(TIME/Date SET is opt: #101)
Instructions for answering system start on page 39...
You have two (bunches of) options (it appears):
To ERASE
EVERYTHING (no indication this is recoverable)...
Merely press "ERASE" twice while the unit is not in use.
Probably a better idea would be to listen to you collection
use the base controls to skip, pause, forward, back, save and erase... and free up some time that way... I'm just saying
Can also ERASE EVERYTHING from remote hand-set...
- Press the "MENU" #324... use up/down arrows to select "yes" and listen to each message... administering (delete/save) as you proceed ... when you are finished press "OFF"
or to ERASE ALL...
"MENU" #325... use up/down arrows to select "yes"
Remotely phone in... Use YOUR Panasonic default code = 111
Unless you have
DEACTIVATED "remote access" you can access your recorder from EVERYWHERE... and follow the voice prompts...
Single key options are available on page 43.
Nice system... Hope this helps.
Expandable Cordless Phone with Large Keypad 1 Handset
