How to fix document feeder on HP Officejet Pro 8500A Plus
Document feeder accepts document but after taking first sheet into feeder it stops and message reload document and restart job appears
Powering down and restarting doesn't help
If the automatic document feeder (ADF) does not pick up any pages at all, the rollers
inside the automatic document feeder need to be cleaned.
If the automatic document feeder picks up multiple pages instead of single
sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document
feeder tray, and then press Start Copy Black
to pull the pages through the
automatic document feeder. The plain paper releases and absorbs residue from the
rollers and separator pad.NOTE:If the automatic document feeder does not pick up the plain paper, try
cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened
with distilled water.
If the problem persists, or the automatic document feeder does not pick up the plain
paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face
plate from the front of the automatic document feeder, access the pick assembly
inside the automatic document feeder, clean the rollers or separator pad, and then
reattach the face plate.
you can only print from an ipad using the airprint app if you have one of these printers
read more about it here
http://www.apple.com/ipad/features/airprint.html
Hi Check the following --Check the paper in the ADF (automatic document feeder) --Make sure the ADF pick assembly is in good working condition --Remove the document feeder and open the ADF cover. --While lifting the blue-green lever, carefully rotate the pick assembly toward the open ADF cover until it stops. --Make sure the bottom roller is held firmly in place by the two-catch, which is located to the left and the right of the roller. --Clean the rollers and separator pad
This link will take you to your users guide on the HP web site. Go to "Maintain and troubleshoot">"Clean the device">" Clean the automatic document feeder (ADF)".
It only takes a small piece of paper left behind, 1/4" square or less, to keep document feeder from working properly. GOOD LUCK!
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
