What does error F:16 indicate?
It would be helpful to know tha make and model. Different manufacturers use the same code for different things. Can't tell from the picture (It looks a bit ike a Whirlpool)
Error: F16,
Machine: Washing machines & Washer Dryers,
Type: Standard,
Fault: Water level far too high. Check pressure switch, pressure hose (for blockage or disconection)also the pressure chamber for blockage
Error: F16,
Machine: Dishwasher,
Type: Bosch EXXCEL,
Fault: Door not closed. Check door is closing properly or door switch.
Error: F16,
Machine: Washing Machine,
Type: whirlpool (not every model),
Fault: Faulty control unit.Check wiring connections, replace unit.
Error: F16,
Type: Dyson CR01,
Fault: Motor fault.(Faulty triac).Check motor and associated wiring, check module and connections Faulty tacho. check tacho and associated wiring, chech module for loose or defective connections.
Error: F16,
Machine: Washing machine,
Type: Bosch WFP Series,
Fault: Rinse sensor is fault.(This error code will only show up in test mode).
