Hi Rosa
Depending on the severity of the broken lid....
I fix a lot of plastic items with either super glue or 2 part epoxy resin.
Then for reinforcement at the edges. I take a 2cm (aprox) piece of thin wire. Like a staple. Then heat it with the soldering iron. sliding back and forth until the wire is embedded into the plastic. even slightly covered over.
This often makes a cracked piece of plastic quite strong.
It may not look great but it might hold you over till you find a replacement
Good Luck
Here are some ideas....
Repairing plastic parts
How to Fix Broken or Cracked Plastic or Weld Plastic
Testimonial: "thank you but i realy like to buy a new lead i will try your ideas"
