So what is the connection ? USB or Wireless or Ethernet ?
Did you try connecting though other ports ?
Connectivity, standard
see wireless setup shown in the below video at 24.34 minute mark
HP Officejet Pro 8610 Unboxing Setup
A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/nJ7AgN. Select your operating system, download and execute the file.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
USB connection.
1. Disconnect the printer from your computer.
2. Re-brick your printer.
Pull out the power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers
and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB
connection. To check, go to Control Panel > Printers and Faxes. If you see a
new Lexmark print object in the list, then try to print a document again to
verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/ngaKcu. Select your operating system, download and execute the file.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
A
If
1.
2.
Rebrick (pull out power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds).
2.
On your computer, go to Control Panel > Printers and Faxes.
3.
4.
Reboot your pc.
5.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
A
If
1.
2.
2.
3.
4.
Reboot your pc.
5.
6.
list again, then try to print again.
You
may also try to update your printer driver by visiting the Lexmark website at .
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
A
If
1.
2.
seconds).
2.
3.
4.
Reboot your pc.
5.
6.
list, then try to print again.
You
may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/dbCiI6.
