SOURCE: Brand new spa, pump doesn't seem to be working!
I imagine the clicking you are hearing is the relay at the end of the switch (air or electric) that is trying to turn power on the the pump. Since any of those issues would be covered under manufacturers warranty I would suggest you get in contact with them in order to retain your warranty coverage. Even if it turns out to be a disconnected wire or bad relay, fixing it yourself gives the manufacturer the opportunity to void the warranty and potentially leave you stranded with a mess on your hands.
SOURCE: I have and old sequoia spa that works great except
If the jet button is an air operated one, you can try to unscrew the button assembly and possibly reconnect the air tubing to it. Some air buttons come apart from the top, some from underneath.
SOURCE: Intermittent jet problem on Spa form hot tub
Hmm, that's an odd one. It could be either a fault with the PCB or the pump.
The first thing to check is the voltage to the twin speed pump. If that's ok the motor is probably the cause of the fault.
As always, with anything electrical you need to be very careful with what you're doing and if you're unsure seek professional help.
Regards,
Ian.
http://hottub.synthasite.com
This sounds like a back circuit board to us.
rod
uspartscenter.com
TRY DISCONECTING THE DISPLAY..LEAVE DISCONECTED FOR 30 TO 40 MINUTES RECONNECT SEE IF THIS FIXES THE PROBLEM
still broken
