Panasonic KX-T7730 Corded Phone Logo
S
Sam Viator Posted on Mar 14, 2016
Why when I try to type name for extension, only numbers come up?
Hi We have a Nortel T7316E phone system. Staff
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344 (with the handset in its cradle).When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on. (i.e 202)
Then press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name(Traci).
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Winston = 9 -> 4,4,4 -> 6,6 -> 7,7,7,7-> 8-> 6,6,6-> 6,6
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
How to program an internal extension number and then give it a name by using alphabet how to change a name tag on an existing internal extension number
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display say Name.
press the Chng soft key. (or the clear key to erase)
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
I NEED TO FIND SOMEONE EXT.# WHEN THEY CALL ME IT SAYS THERE NAME BUT I NEED TO KNOW THE EXT#
You can either do a button inquiry in each of the extensions to see which extension number is associated with which name. that is done by going to each set and pressing feature *0 then pressing the intercom key. or you can look through set programming to find out.
The display should now ask for an extension number. Press the list soft key.
It will list the extension number followed by the name for the first extension.
Press the next key for the next extension (bottom right arrow) .
32helpful
3answers
How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
4helpful
I am trying to delete an employees name from an extension
Programming2.gif is done on 7310, 7324 and 7316 type sets.
4answers
How do i change the extension ID on Panasonic KX-T7731
If by ID you mean name, it's done in SYSTEM programming. That location changes by system model number, but usually it's in either 004 or 604.
If you mean something else, please comment back.
Carl
Changing the names fixed to internal extension numbers
If you can not log into the programing tool to change it that way then you will still need the Installer password. However from the main ext typically the first ext or 101
hit the Program soft key just below the LCD
push * then #
password
004
ext number you wish to change
type in new name
ENTER
END
9helpful
Lucent MLX-20L Extension Edit
http://dstech1.com/changing-the-name-on-an-extension/
A label can have a maximum of seven characters.
To administer Labels for Extensions from the System Programming console:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit or Start.
  4. Press More or Right Arrow Key.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  8. Dial the extension number that you want to administer.
  9. Press Enter.
  10. Press Drop.
  11. Enter the label information for the extension number selected.
  12. Press Enter.
  13. Press Exit or Back.
  14. Press Home or Exit to exit programming mode.
Note: When programming on the system programming console, use the buttons next to the display to specify the letters A through I and punctuation. Use the line/feature buttons to specify additional alphanumeric characters for labels. Use the template provided with the System Programming console to see which line buttons correspond to which alphanumeric characters,
The resource cannot be displayed The page you are looking for cannot be opened by your browser because it has a file name extension that your browser does not accept....
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this problem, make sure that the Accept header of the client request matches the MIME type that is specified for the requested content file name extension on the server. To do this, follow these steps: 1. Start IIS Manager. To do this, click Start, click Run, type inetmgr.exe, and then click OK. 2. In IIS Manager, expand the server name, expand Web sites, and then click the Web site that you want to modify. 3. In Features View, double-click MIME Types. 4. Double-click the MIME type that you want to modify. 5. In the Edit MIME type dialog box, type the appropriate MIME type for the content file name extension in the MIME Type box.
Note You can also set the MIME type of the content file name extension to */* to accept any MIME type
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
Initialising Mailbox
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
To Change the "Recorded" Name for the Company Directory:
1. Have the Voicemail User log into their mailbox, after putting in their password, press the button under "Admin" (or press the number 8 key., and then press the number 1 key.
2. You will hear the old recorded name and then the system will "beep", prompting you to record a new name (name only here, not greeting..
3. Press "Ok" in the window when you are done recording and then "Ok" again to accept the recording
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
