The owner's manual will usually show a list of error codes and possible resolutions in the Troubleshooting Section. Further research shows, it is an internal fault:
Frequently Asked Questions
If you mean the foot controller, then the T/FC-322 is a substitute that should work. It's listed as a replacement here: http://www.sewingmachinesplus.com/234522001.php . The manual for the NX400 gives the foot controller as XC1154-051 . Brother changes the part number often but the wiring remains the same. Another substitute controller is available here: http://www.sewingpartsonline.com/foot-control-w-cord-brother-xc6651121.aspx .
The F04 message may mean there is an internal failure. This probably needs to be fixed by a Brother authorized repair person.
I wish that I had better news for you.
SOURCE: I have a Brother Innovis
I know this isnt of much help but my manual says that any errors starting with F is a sign of malfunctioning and should be taken in to a service center. Wish I could help more.
SOURCE: Walking Foot for Brother LS-1217
Beckster, it may simply be that the walking foot needs to be tweeked a bit, perhaps screwed in further, or less.
If that doesn't help ...
Check out this site. All the Q&A answers in simple language, as
well as a GREAT cust. support staff. (its a Brother after all!)
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/model_top/HomeSewingMachine/hf_ls1217eus.html?reg=us&c=us_ot&lang=en&prod=hf_ls1217eus
SOURCE: i can't sew on my machine
I had the same problem.There is a gold or silver washer on the back of the sewing machine that holds the part inside that you are connecting to. If the washer is gone or loose you will not get a connection when you insert the foot peddle. This peice inside is small and square with three delicate wires attached, You should be able to see it
SOURCE: well i have my brother nx 400 over 6 years and
Hi. Yes, it's true. Brother does have self-oiling sewing machines (I have a Brother CX-8060 that's also self-oiling.)
Hope this helps!
Robbie
SOURCE: keeps giving me the Fc warning signal no matter what I do
The foot control has been disconnected while sewing. Turn off te power and connect the foot control.(connected to foot pedal on the floor has come loose from machine body)
