I dropped the starter bolt in the hole where the starter goes
If it is an automatic, try removing the cover under the flywheel to get at the bolt
if such a cover is not available as in a manual I would go to a good auto tool shop and purchase a flex wand with a magnet on the end and try that
there may be a small hole with a rubber plug in it in the bell housing under the flywheel that may give you access as well
If nothing works after you have used a lot of imagination then you know what will have to be done --box out
