Question about Bunn-O-Matic Coffee Brewer GRW8
I lost my manuel for my Bunn coffee maker. I
I lost my manuel for my Bunn coffee maker. I would like to know how to fill the water resevoir. The steps in filling it. I put 10 cups of water in to make coffee, and only 8 cups of water come into the pot. I think the resevoir needs more water. I can't remember exactly how to do it. Thanks
    New Friend:
    Problem Solver:
  • 12 Answers
    New Friend:
When i fill my coffee maker the resivoir is full and hot but when i pour water in to make cofffee the water seems to leak from the bottom or thro the sides cant see exactly where
Posted on Jul 02, 2012
  • 22 Answers
SOURCE:
I have a bunn coffee maker the nhbx is the # it is leaking water from the resevoir
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
May 12, 2010 | Bunn NHB Coffee Maker
Leaks water from the top resevoire
Either your fill tank is clogged, or your washer seal is cracked. You will need to remove the top of your Bunn to access this area. In the resevoir you will see a large nut with a drain hole. First try clearing the hole with a tooth pick and pour water in the basin. If it flows you have good drainage. Now, with the top still removed, pour water in the basin while checking for leaks. If a leak is present you should remove your drain nut and inspect the clear white looking washer on the underside. If it is cracked you can replace it with a gasket from Bunn. If you are tight on time and cash, a non rubber heat proof water hose gasket will suffice until yours arrives from Bunn. Replace and re-tighten the basin and drain nut (do not over tighten) .
Feb 01, 2010 | Bunn VPR Coffee Maker
Coffee is in water is in nothing happens
You may not have enough water in the tank.
Follow these steps
1. With the coffee pot unplugged, fill your resevoir/tank until water begins pouring out of your sprayhead and brew basket.
2. Wait for the water to finish dripping then plug in your Bunn.
3. Let your Bunn warm up for at least 8 minutes.
4. Run a test cycle with clean water, remembering to use the water pitcher provided for this purpose, while leaving your empty pot on the burner beneath the brew basket.
5. If your cycle completed, and your coffee pot is filled to the desired level you are ready to make coffee.
Remember that these Bunn models have no water filter2_bing.gif installed, so, the cleaner the water the better tasting the coffee.
Jan 04, 2010 | Bunn VPR Coffee Maker
Resevoir tank not filling
If you will get the model and date code located on the bottom of the unit and contact customer service, we will be able to help troubleshoot and resolve your issue.
May 11, 2009 | Bunn NHB Coffee Maker
Water over filling pot
The procedure for setup of this coffee maker can be found here -
http://www.bunn.com/pdfs/commercial/manuals/10613.0000.pdf
Please email if you have additional questions.
Feb 02, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
We have a Bunn VPS 3 and we need to know how much water we should keep in it ?
You should keep the unit full of water all the time it's plugged in, as if it is low on water, the heating element will burn out. A Bunn VPS brewer holds about 2 -64 oz pots of water in it's resevoir.
Jan 21, 2009 | Bunn VPS Coffee Maker
Bunn BT 10B -RANCID BUTTER in Resevoir!
Hi Tina - I'm no expert on melted butter in your coffee maker; but, I'd bet that the butter also got into the internal water tank where the water gets heated. Try going to the Bunn website: www.bunn.com , and click on their Customer Service link. You can either call their toll-free number or write to them with your problem from there.
Hope this helps!
Jan 13, 2009 | Bunn BT10B Coffee Maker
Water leaks out of holes up under resevoir.
Use a Torx T-9 tamper resistant screwdriver to remove the screws on the bottom of the coffee maker.
Your plastic tube has probably come loose or is leaking. Carefully re seat the plastic tube over the metal tube using the metal spring compression clamp.
Jan 09, 2009 | Bunn NHB Coffee Maker
Pumping more water out than what i put in
This coffee maker uses a resevoir tank system - the water you pour in pushes out water that is already heated - the water you pour in won't actually be used for that pot of coffee! For that reason you should only use full pitchers when filling. You may need to cycle through 2 or 3 fillings before the input matches the output once more. The capacity of the resevoir is about 3 pitchers; you can brew 2 pots in a row before the machine needs a break to bring the resevoir back up to temperature.
Nov 12, 2008 | Bunn VPR Coffee Maker
Bunn-O-Matic Coffee Brewer GRW8 Logo
482 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
