If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
SOURCE: Akai LCT 26AE Universal remote codes for RCA remote
i cannot find the model # to my akai tv/dvd combo where is it? AND ALSO I DO NOT HAVE THE REMOTE TO IT LOST IT DURING MY MOVE. HOW CAN I PURCHASE I NEW REMOTE OR WHICE UNIVERSAL ONE SHOULD I BUY! PLEASE HELP
SOURCE: Akai LCT 2701 TD - Red Blinking lIngt
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to [email protected]
SOURCE: Akai LCT 2662 will not turn on
I can repair your power supply for you. Please email me at [email protected]. Thanks.
SOURCE: I am trying to program my directv remote D10-300
use the auto mode first make sure you have the device on first then in the instructions it tells you how to put the remote in the auto mode. follow the directions usually putting the mode in the search mode then pressing the power button slowly untill the set turns off. you will need to look at the remote manual to be sure or it is also on the website for your provider then you press the enter key. if you go through all the codes and the button blinks twice or goes off than your tv set cannot be used by the remote you have dont go to fast as you may need to do it all over again if you go too fast as you will skip over the right code. a lot of folks ask for codes but unless you have a programmable remote or a l4earning remote you cannot enter codes into a remote as all the codes are already flashed into the ROM chip inside the remote.Good Luck!!!!! techman
