I had the same problem - my fix is simple, cheap and works great - obtain some of those double sided hook and loop (Velcro) straps used to tie
cables in a neat bundle - the 3/8" - 1/2" wide version works best, these are approx 4" long and usually black in color - costs approx $2 for a package of 10 straps.
Cut off a piece from one of the straps, approx 1" long and glue this to on side of the neck of the charging base. Glue the reverse side of the remainder of the Velcro strap to the other side of the neck, position it with enough length to go over the top of the push in plug (when closed), at the top of the neck, and cover the full length of the first piece of Velcro glued to the other side of the neck + remember allow some additional length so you can easily grab the end of the long piece to release the Velcro grip and let the plug raise clear of the razor.
When the glue is dry, pull the long end over the top and position it to hold the neck plug completely down, and be retained by the first piece of Velcro on the neck - trim the long piece to length, remember you need a little extra length, to make releasing the Velco grip easier. I just pull on the long end of the Velcro, this closes the plug into the razor and simply push the Velcro together to start the cleaning process - simple and cheap.
Mine has been working for years.
