Need instruction manual for r-wave desk clock
SOURCE: I am looking for PDF or online instructions for
Go to seikousa.com and email cust service. They will email you an acrobat version.
SOURCE: need users operating manual for seiko qhr016
The time should be done on automatic by pressing WAVE.
To set manually:
Press the [SET] Button for more than 2 sec. The Year will pop up set to correct year then press SET again to set date/mth, keep holding till it get to right month n date (the month and date does not set separately). Press SET again and set TIME then press SET again for your choice of 12hr or 24hr.
SOURCE: I need the instruction manual for the SEIKO
I just found mine, could email to you
has several languages
What rules are there?
SOURCE: I HAVE A SEIKO GLOBAL
Remove the battery cover, press and hold set until it beeps. Use the up down keys on the front and you cycle through year, month/day, then time, then 12/24 hour mode. You advance to each function using the set key. Once through the cycle, the time will stop flashing and the clock will function normally.
