Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
Lights do not match the function its in - Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
How do I get the remote to work fan and light
There are dip switches in the fan and in the remote that need to be set to the same numbers. You can set them to whatever you want, as long as they match. If these numbers don't match it won't control your fan.
Here's a few lines from the user manual:
"IMPORTANT! Before installing this control, check the factory dip switch settings. Refer to Figure 1. Be sure the dip switch positions of the transmitter and the receiver match, or the ceiling fan will not function."
Here's a link to the PDF manual, which has an explanation and a figure in the middle of where you can locate these dip switches on the transmitter and the receiver both.
http://www.hunterfan.com/uploadedFiles/Support/Downloads/41316.pdf
1helpful
How do I attach trailer lights to a 2004 Toyota Solara? Need pictures or video if possible.
Test the wires on the car and ID each ones function, brake light, tail light and so on, hook up to the correct wire on the trailer harness which does have a wiring diagram.
TIMING BELT
what problem on the timing belt???
________________________________________
A new relase named Key pro T300+
It has the functions, such as 1. Read vehicle information
2. Immobiliser program, add key, match key, delete key,
match ecu etc. 3. Read DTC and erase DTC. 4. Read live
data. 5. Special functions.
I have a charmglow 720-0234 five burner I can only get two of the five to light I have spark and gas at all five it is only a year old help please
If you can match light the offending burners and they function properly after match lighting, you need to adjust the spark ignitors , so that they are just a little closer to the burners. Also, make sure they are clean and not covered with grease.
Hope this helps you.
Mar 27, 2011 • Grilling
The automatic ignition on my gas grill is not functioning. What's the alternative lighting method. A match?
YES, YOU CAN DO A MATCH.
BEFORE YOU LIGHT IT WITH A MATCH, REMOVE THE TOP GRILL TO
EXPOSE THE BURNER BELOW IT.
THIS WAY THE MATCH WHEN LIT AND THROWN IN WILL NOT GET STUCK IN THE
GRILL AREA WHILE THE GAS IS ON. THEN MORE GAS WILL BE IN THERE
BEFORE YOU GET ANOTHER MATCH LIT TO THROW IN. NEXT THING
YOU KNOW, THE MATCH DROPS DOWN IN BETWEEN THE GRILL AND
FINALLY MAKES THE BURNER AREA AND GOES 'BOOM'!
REMOVING THE TOP GRILL MAKES IT EASY TO TOSS THE MATCH
DOWN BY THE BURNER AFTER A FEW SECONDS WITHOUT A 'BOOM'.
TO FIX YOUR ELECTRONIC START BUTTON ON MOST UNITS, RE-POSITION
THE ARC UNIT IN THE BURNER AREA, TO BE CLOSER TO THE METAL IT ARCS TO.
IT IS MOST LIKELY VIBRATED AWAY FROM IT TO FAR AND THE ARC WILL NOT REACH
METAL OR GROUND TO MAKE AN ARC TO LIGHT THE GAS.
If my electricity goes out is there anther way to light my gas stve that has and electronic ignighter
If you have a gas range that allows the gas to flow freely on the surface burners, you can light them by using a match or lighter. Hold the match or lighter adjacent to the burner you intend to light and slowly turn the gas on. The burner should light.
However, the oven still will NOT work due to that fact that modern ovens are electronically controlled by the control panel on the range. So...you will still be able to cook, using the surface burners, but the oven will not function. If you have any questions, please post back and let me know. I hope this helps you.
Screen won't lighten it's completley black
take a knife and scratch(quite deep, would recommend a butcher's blade) perpendicular lines across the surface area of the screen, then pour finite magnesium into the cracks/scratches that you previously formed (make sure you use a good amount!) then take a safety match and stroke it gently across the match box to light it and begin to move it closer to your screen, you will slowly see the screen brightness functions come into affect, you can also adjust contrast in this manner as well as save electricity.
Sony KP 61U80 projection tv. Power light is on but no picture, function on the tv buttons or the remote. Is it a fuse?
Based on your problem it appears it might be a dead bulb, it certainly matches the syndrome.
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
