Samsung LN40B650T1F is turning on, picture is flickering, and after 30 seconds the picture goes out and the sound stays...any ideas of what will fix this?
I'd look at a bad panel, the defective panel damaged your main, replacing that got it working somewhat but if it's on very long I'm guessing you will damage the main board you replaced. Try unhooking the ribbon connectors one at a time and see if half the picture works ok, if so you definately have a bad panel
The picture board on your monitor has been malfunctioning for quite the period but you did not notice it, since the screen goes blank, it means the
board of your monitor has developed fault and will need to be replaced.
The best thing for you
to
do now is to take the monitor to a local repairer within your vicinity
to help with the replacement of the picture board
because the fault is not something you can fix yourself, in order not to
complicate issues.
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
This could be a number of things. Your lamp could be bad or it needs to be reseated to the ballast. The lamp is trying to light and it will make the ballast flicker (that is the clicking sound) or your ballast is bad and it needs replaced (it will flicker and click too). Or your color wheel is broken and it will make a clicking sound when turning. If the color wheel is not spinning or broken it will not light the lamp. No lamp no picture.
