I did try to replace the t-con board, i got a used one, i don't think i got a good one because i had no sound or back lights with that board, i reinstalled the original and got my back lights and sound back, should i consider buying a new t-con? thanks
Something else is going on. The T-Con board has no other function than controlling the picture. If there is a separate board for the led drivers, I'd suspect that one. The main board controls the sound.
Testimonial: "the lcd driver is built into the t-con, its a un60eh6002f, i thought i was ordering a new board, i should try the new one, what are the chances the lcd screen itself is bad? thanks for the reply."
.01% chance the screen is bad. It happens, but the symptoms are different than yours. It's possible that the used T-con board was pulling down some of the voltages from the power supply board which would affect the main board and the ballast board. That would explain what happened when you installed the used T-con board. Get a new board from shopjimmy.com
