Roper REX4634KQ Electric Dryer Logo
Karen Fisher Posted on Mar 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The start button does nothing
Start button does nothing
David Ellis Rhea
Level 3:
  • Roper Master 3,462 Answers
  • Posted on Mar 10, 2016
David Ellis Rhea
Roper Master
Level 3:
Answers
3462
Questions
Helped
784853
Points
10903
Start buttons seldom fail, but door switches fail often.
Have someone good at this open the lid and bypass the door switch, it should start fine.
Door switches can be bought at Amazon or "Sears Parts Direct" or e-bay.
God bless your efforts.
How can I restart my dishwasher
Press and hold the start button for a few seconds. The dishwasher will drain and reset
883 HD sportster was running fine and then turned
If when you push the "start" button, and get a rapid series of clicks, it's a low battery, or a bad connection.
If you get a single, louder click, it's the stater relay.
If nothing, start by testing the starter button itself, and checking all the related wiring for breaks.
Sep 23, 2014 • Motorcycles
Start button collapsed
There is a control module behind the button, maybe the screws became loose and it is falling away.
5helpful
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
3helpful
2answers
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 • Dryers
2answers
Singer ce100 start button
Hi Vanessa,
Please give me more info in order to help you. Are you trying to use the embroidery unit? If yes, did you send a design to the machine via your computer?
Top Roper Dryers Experts
ZJ Limited
ZJ Limited
Bill Eager
Mike Cairns
Mike Cairns
Are you a Roper Dryer Expert? Answer questions, earn points and help others
