Keurig Platinum B70 Coffee Maker Logo
D
Donald V DeRyckere Posted on Mar 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When power is turned on the word prime appears in the LCD control center screen and the water low lights flash in the water reservoir but reservoir is full What is wrong?
I flushed out the valve at the bottom of the reservoir. That did not help.
Bill Boyd
Level 3:
Top Expert:
  • Keurig Master 53,816 Answers
  • Posted on Mar 10, 2016
Bill Boyd
Keurig Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949213
Points
172802
The word prime means that you have to fill the unit first so that all air is removed
check for some sort of bleed valve /screw at the top
fill the unit first then connect it all up
all these sort of instructions will be in the user manual for you to follow
How to prime
http://www.keurig.com/~/media/DD2E19AE632A45BDAA55D72706420B74.ashx
^^^^ that's the owners manual.
according to it,
LCD Control Center
indicates "PRIME"
and the blue light in
the Water Reservoir
is flashing
Solution:
Completely remove the Water Reservoir and
thoroughly clean (refer to page 14). Ensure
the Water Reservoir is fully filled with water. Return it
to the Brewer and ensure it is seated properly
(refer to page 6).
If you have completed the above procedure two
times and this situation persists, contact Customer
Service at 1.866.901.BREW (2739
tip
Saeco, Gaggia, Spidem VENTILATE, Prime what is mean, how to perfrom
Ventilate or priming or else loading all means the filling the machine system full with water, like pump, piping and boiler. This must perform first time of starting up the machine.
It will also appear if the water system in not full of water especially after the steam preparation some steam can be blocked in the system and the machine recognized it by luck in the pressure.
Another reason that ventilate it appears on screen is because air have been insert and blocked in the water system usually from water filter or water softener located in water tank.
So here how you Ventilate or Priming or loading:
Place a container beneath the steam tube.
Turn the knob counter clockwise to start loading the circuit.
Wait until a steady stream of water flows out from the nozzle.
Turn the knob clockwise
to terminate the circuit loading process.
Remove the container. The machine is warming
up; lights are flashing.
Note: You must load the circuit before starting up
the machine for the first time, if it has been inoperative
for a lengthy period or if the water tank has
been completely emptied. The circuit must also be
loaded each time the light flashes
Saeco vienna plus red solid light cannot prime water line
Make certain the line from the water resource is cleaned and not obstructed. If the pump fails to move the water from the reservoir to the heating tank, then the pump needs to be replaced.
Blue flashing light and says prime
The PRIME is important. If you looses the prime, you cannot lift the water up and into the reservoir for heating and eventually flowing to the Kcup and beyond. Full the Water container all of the way to the line (not over), prime as per the manual, with the handle fully engaged, see if that fixes the problem.
Is prime the same as descale
I knew the paperclip trick, I tried the air shot to reverse the flow of water. After running Vinegar and water through and letting sit overnight. I tried the air blast then make a cup, another blast X 4....though I get a good flow through the K-cup area, I still only get 2/3 cup of water.
My keurig light in the water reservoir flashes and in the screen appears PRIME what does mean?
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
54helpful
4answers
Starbucks Sirena espresso flashing blue light & does not heat up
Gary,
I have the same exact problem with mine starting today, did you get this figured out? I'd love to know if it's fixable or not as I was planning on selling my previous machine. If it's an expensive repair, I'll just have to ditch this one and go back to my previous one.
5helpful
3answers
Saeco Caffe Charisma lights do not stop flashing
I had the this same issue and made a post to this thread, in that post I had this solution to my conditions.
The combination of actions that seem to work was turning the Saeco on while the steam valve was already open and selecting hot water once the Saeco was powered on. The prime light went out, I closed the steam valve
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
