Televison & Video Logo
B
Betty jean Brooks Posted on Mar 09, 2016
Who makes Crosley tv. please
I have no remote for it really need to know who makes them so I can see if I can so sound on and off. I have dish sattlite the Joey can I use that remote to fix this and if so dose anyone have the codes thank you
How do i program dish remote to a vizio tv
Please follow the link below or using the second link below select your remote. If you don't know what model you have you may cycle through the list and it will provide you a picture of the remote. Just make sure you match it to the best of your abilities. Or you may contact Dish and ask what model your remote is.
By Scan
Tech Remotes Remote Codes MyDISH Customer Support
Please note that if the codes are not available or if they are not working then Dish nor Vizio does not have any working codes. Please understand that these codes are not universal for every remote nor is Dish and Vizio responsible to provide you with a fully working code.
Insignia soundbar
I have listed the steps below to assist with programming the remote to your Sound bar. Please know that we do not promise your remote will function with your sound bar. If you have any other questions, let me know at [email protected]!
Visit this link to obtain the code/s to address remote to sound bar: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear AUX button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The Aux button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code and try this procedure http://www.mydish.com/support/program-to-tv-scan-non-basic?WT.svl=leftnav
Kimberly Escobar
Social Media Representative
DISH L.L.C
Cant change channels on my new Vizio HDTV with the dish network remote
There is no setup codes for Vizio TV with Dish Remote control.
2helpful
Recent IR20.0 remote problem developed after 2 years without any issues. The remote no longer communicates to my 722k dvr reciever while my LG Tv is turned on. I have Hdmi run directly from reciever to my...
Hi Robert, my name is Cheri Torres and I work on the Social Media Team at DISH. It sounds like your remote is experiencing IR(Infrared) interference from your LG TV. You can resolve this issue by converting your TV1 remote to UHF(Ultra High Frequency) instead of IR. In order to do this you will need a UHF remote, the 20.0 remote is only an IR remote. Please email me directly at [email protected] with your account number or phone number on the account so that I can look into getting a UHF remote sent out. Thank you.
Cheri Torres
DISH L.L.C.
[email protected]
2answers
I am trying to set a dish network to control my samsung dvd-1000 and a daewoo tv
Hi henry walters,
I know it can be frustrating trying to get the codes to program equipment. You can view the link below to search for any codes you may need for your equipment!
Link: http://www.dishnetwork.com/SupportSection/apps/remotecodes.aspx
Let me know if you have any other questions!
Tommy Faust
DISH Internet Response Team
I'm hooked up tp Dish Network an hit wrong button on top for volume and now pic is gone. in lower left corner says no signal., but dish is working, just no picture on screen
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like you are going to need to change your TV back to the proper input or channel. If the TV remote is not working to change the channels you can also use the buttons on the front of the TV. First look for a button listed as either input, TV/video, source or AUX. When you press this button it will start cycling through all the inputs available, make sure to cycle through them slowly because it make take a couple seconds for the picture to come in. If you do not find a picture on any of the inputs you are going to need to try the different channels. Normally for a TV where the receiver box is the TV should be set to channel 3 or 4. Once you have found your DISH Network picture you will want to make sure to push the SAT button on the DISH remote so that it doesn't change the TV channel again. I hope you find this information useful and if you have any further questions or concerns please let me know. Thanks. :)
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
2helpful
2answers
Code for trutech
dish network remotes dont work with very many tv/vcr or tv/dvd combo units
Crosley tv
hi Tessnado.
this is all i can find to do with the crosley tv.
this link will take you to what might be of help to you but not sure.
Crosley Look Through TV Questions
or try this link.
crosley tv stuck on demo mode Google Search
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
