Question about Exercise & Fitness
Precor elliptical says stuck key on upper display and sometimes flickers or doesn't even turn on at all.
If it does turn on the elliptical resistance won't work. A repair man tried a new battery which didn't work. He thinks it might be the lower PCA board, Upper PCA board or the generator. Does anyone have any thought on this?
    New Friend:
  • 10 Answers
A stuck tek generally means the hard overlay (with buttons) is faulty. I have seen where the entire console needed to be changed. The battery may have also been bad but this would have been for the flickering only.
877-805-1030
Book An appointment
Precor elliptical says stuck key on upper display  - 26123891-ahtutwr5skls1b4kbgpnggrt-3-0.jpg
Posted on Apr 23, 2016
5 Suggested Answers
SOURCE:
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
SOURCE: the resistance on my Precor elliptical 5.17 will
There is a small motor under the shroud that operates the resistance motor. It is about the size of a roll of half dollars. Have someone use a meter and check that you are getting power to this. When you turn on the machine the motor should move the resistance forward then back. You can hear this everytime you turn it on.
Posted on Mar 11, 2010
SOURCE: Schwinn 431 Elliptical doesn't register rpm's, distance, etc.
I have this same problem and called the customer service. The problem is that the rpm sensor is not working. It could be the sensor or something else. They had me check the connections first for the wiring harness at the top and middle and then sent me parts to work on the inside where I have my problem. I am still working on mine because the magnet was installed on the wrong side of the flywheel. Hope you don't have this issue.
Posted on Jan 08, 2011
info95456
  • 10 Answers
SOURCE: My Precor EFX 5.17i elliptical trainer keeps displaying "Error 40" even when I turn it off and back on. How can I fix it?
This is an incline error. Check fuses and incline gear for jammed incline. Call 877-805-1030 or www.techmotionusa.com for service tech if you still need help
Posted on May 09, 2015
Stuck key on display
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Dec 28, 2013 | Precor EFX 546i Elliptical Version 4
Precor EFX 546 05 stuck key
Corrective Action
Jul 02, 2013 | Precor EFX 546i Elliptical Version 4
Efx stuck key
Corrective Action
Mar 30, 2013 | Precor EFX 546i Elliptical Version 4
"stuck key" message on efx 546i, will not engage, already replaced batttery
Corrective Action
Feb 17, 2013 | Precor EFX 546i Elliptical Version 4
I get the message error 05 stuck key on my precor efx 546
Corrective Action
Dec 09, 2012 | Precor EFX 546i Elliptical Version 4
546i stuck key elevation does not work
Corrective Action
Jun 02, 2011 | Precor EFX 546i Elliptical Version 4
My Precor EFX 546 Elliptical machine has a "key depressed" error message.
Corrective Action
Aug 17, 2010 | Precor EFX 546i Elliptical Version 4
Change batteries in consol of elliptical, but still the resistance or tension does not change or increase
their maybe a loose connection between the upper display and function controls I would pull apart the upper display and check the connectors between the two boards
Feb 28, 2010 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
1,277 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
