Washing Machines Logo
John Englert Posted on Mar 09, 2016
Fault 49 pops up on the screen - Washing Machines
PegiS
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 9 Answers
  • Posted on Mar 09, 2016
PegiS
Contributor
Level 1:
Welcome Back:
Answers
9
Questions
0
Helped
8420
Points
20
If your washer is a Fisher Paykel Top-Load Washer Error Codes = 49 I found this online by typing "Washing Machine Fault 49" into a google search engine...
Error Fault Condition - Water Inlet Valve Fault.
Repair or Check - Unplug the washer from power. Reconnect any non secure wires on the water inlet valve. Replace the wire harness if it is found to be damaged. If the wiring is okay then measure the resistance of the water inlet valves using an ohm meter. If the resistance of each water inlet valve solenoid is not 60 to 62 ohms then replace the complete water inlet valve assembly.
Parts for Replacement - Water Inlet Valve Assembly or Wire Harness.
49-2F9D Service error
49:xx xy fault code is Firmware crash , look at the 49 error as bieng like a blue screen crash on windows, there are many things that could cause this to show- what to do-
disconnect both the mains cable and any other network/usb cables that are connected to the printer.
allow 20 seconds for the ram to clear. then re- power the printer still with no network connections, allow to come to fready - at this point you should try to get an info page from the printer ( use the menu(tick) button then scroll down once then press menu(tick) twice. this should now print out a information page and also at the same time you will have proven there is nothing wrong with the printer.#
BEFORE re-connecting the network to the printer - CLEAR ALL PRINT Queue's from the workstations (pc) as the likely fault is a corrupt print file, if you dont clear the print queue then the printer will attempt to print the failed file again and again and again and again and ag-sod it you got the idea
Fault code 49
Fault code 49 is a valve fault, but I have found it to often be the motor controller board at fault.
Fisher paykel aquasmart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
1helpful
Fisher paykel aqua smart fault 49
I have a model WL80T65CW1 aquasmart washing machine. It stopped working and showing fault 49 on screen. I do not have a manual. Would you please tell me what fault 49 is?
In AquaSmart machines the pump over-currents and blows the water valves fuse, Motor controller board and pump needs replacing.
49. (00110001) Cold Valve or Cold Valve & Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the cold valve or both the cold and hot valve is faulty. The most likely cause is
that the valve harness has not been connected correctly or the valve(s) is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves and
the motor control module or the pins are not bent backwards.
Secondary Source: Water Valves.
Action: Measure the resistance of the cold and hot valve coils.
Tertiary Source: Motor Control module.
Action: Replace the Motor Control module.
Hi my washing machine saying fault 49 on it model WL80T65C
prob the capacitor faulty on motor , or start up windings on motor burnt out ,
Hp laserjet p3005 freezing at times ,at times erroe49.4c02 pops
Hello, 49 errors can indicate a hardware or application error.
The formatters in the P3005 series have been plauged with problems, freezing being one of them.
For more on 49 errors follow the posted link.
Support 49 Errors CLICKHERE
I have an Intuitive Eco Fisher and Paykel top loading machine. When I turn it on a continuous beeping sound comes on with the message Fault Code 49 apearing on the screen. What can I do to solve the...
Hi just read your posting.Error Code 49 means your Cold water valve is faulty,Or your control module is faulty.To test this fault you need an electrical test meter to test the water valve coil for conductivity.Have you or can you borrow a test meter to check the water valve?Please reply on how you would like to proceed and I am sure I can guide you throe the steps needed to rectify this fault.Looking forward to your reply.
2helpful
Top Washing Machines Experts
john h
