Televison & Video Logo
J
Jan Peters Posted on Mar 09, 2016
Sound comes on straight away but picture takes quite a while. Is the screen failing?
2 Related Answers
Anonymous
  • 1476 Answers
  • Posted on Jun 23, 2006
SOURCE: picture disappearance & tv turns off
It sure sounds like you have a classic case of bad solder joints. Resolder all the connections on all boards.
Anonymous
  • 11 Answers
  • Posted on Oct 18, 2012
SOURCE: vizio 48 flat screen has sound, picture will not come on right away
What cable is being used? Often times there is a few things that could effect the picture and causing flicker. If you are using an HDMI cable, or the hdmi plug on the box or tv, you could have that problem. Because the picture is digital, you don't get the snow and lines we were used to. Because the cables are so stuff, often over time they can stress and pull on the plug and cable. Try a new cable, if that does not work, try another hdmi input on the tv. If that fails then try a new cable, like a component cable or RCA. If none of these work and you still have this issue with the box then most likely it is the tv or the box. Swap out a new source, and start this process all over again. If you get the same result then it is the tv. If it works with the same cables, then it is your box. Att will send you a new box if that is the case. If it is the tv, call Vizio. Warranty or not call them. If you are sure you are out of warranty, play dumb, be vague but nice. Often you can get someone out there still at no cost.
What would cause a flat screen tv to have sound but no picture
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from ...I have sound no picture it would take a few minutes waiting before it would come back on . ... and I think I may have causedthis because it's been in for 2 days straight ... ken you helpe samung lcd tv no sound screen is black sound works ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little ... up to the screen, you have to look carefully but if youcan make out the ...
Repair A TV With Sound But No Picture - YouTube
? 2:30
https://www.youtube.com/watch?v=MQj2t4nNVYc
Sep 18, 2012 - Uploaded by MonkeySee
1helpful
No picture on screen
Is the TV under warranty? If it is don't muck around, contact them straight away as you have a electronic problem with your screen.
Before that make sure the yellow chord is in the visual port and red and white into sound. 2) If thats all good try an experiment, as you know the sound is good, use one of the sound cables to replace the yellow. Is there a picture now? If so replace chord, if not make contact to exchange for warranty.
1helpful
Is there a picture tube for the Theaterview Toshiba (1996)? The picture sometimes takes more than an hour to emerge. I have to
if you are getting for the first 15 minutes or so lines or noise left to right on the screen that does go away (but is taking longer as time passes) you have a Hyper board failing---Google that for your set.
2helpful
Tv picture and sound goes away for about one minute and then comes back. After another two - three minutes, the process starts over again, and again. Please help if possible, Thanks!!!
When the bulb goes off with the sound. The lamp is starting to fail andyou need to replace it. Wear gloves when replacing the lamp. UseXL-2400(part # F93087500) replacement lamp. For informationvisithttp://sonystyle.com/tv for US residents andhttp://sonystyle.ca/tv for Canada residents.
  1. Remove the outside lamp cover.
  2. Turn the knob counterclockwise to OPEN and pull out the cover.
  3. Hook a finger through the loop of the lamp handle and pull the handle upwards then pull the lamp straight out.
  4. Put the new lamp in its place. Mount it securely and take extra care not to touch glass portion of the lamp.
  5. Turn the knob back to CLOSE and secure the cover.
  6. Put the outside lamp cover back in its place.
  7. Turn on the TV
  8. Browse MENU>SETTINGS>SET-UP>Lamp Replacement then follow the on-screen procedure.
NOTE:Disposethe used lamp properly. It contains mercury and disposalis regulated..Contact your local authorities for proper disposal.
Screen shows pink
I am afraid your CCD is failing.
Repair not worth it. No spares for DIY available
No picture just comes sound
sounds like the Backlight has failed, if you look closely at the screen you should be able to see the image changing, but as there is no back light there is no luminescense so it will appear black or grey, It is probably the backlight inverter or element that has failed, if this is within warrany organise with them to fix it for free,
Picture disappearance & tv turns off
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
