Was getting code C7 35 water was going from hot to cold now getting code C4 35. Had a pipe leak over night...water got into the wire housing. Dried with blow dryer...now code C4 35 comes up
SOURCE: water leak at top rheem 21v40s-2
you need to replace the water heater, the tank is cracked and under pressure so it is forcing the water to the nearest opening
SOURCE: rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
SOURCE: Hot water gets cold after a couple of minutes
hi do you have 3/4 inch cas line running to it? if you only have 1/2 inch it is too small and running out of gas and shutting down. ed
SOURCE: I am getting alternate C7 and 76 code as unit
called Rheem and after giving them the info they are shipping out a replacement board which I can install, hopefully today..to overcome the hot water problem for the short term I disconnected the remote wires at the heater which lets the heater keep producing hot water albeit without the remote...I will keep the old board as backup in case this happens again as there seems to be problems with the PCB
SOURCE: i get hot water for a couple of minutes then the
O2 Sensor block..need to have qualify technician check it. If under warranty contact Rheem
Testimonial: "Thanks!"
