Question about Health & Beauty
Why will the scooter only move once and than have to wait 10 min for the next time?
Will only move once, have to wait 10 min will move again. go forward, let go of throttle, keeps going, no brake. go reverse, still goes forward but slower, let go of throttle brakes abruptly. checked the wires back to the control box under floor, throttle neutral position is 2.6Kohm, full one way 4.96Kohm, full other way 0.6ohm, no dead spots. Speed control from 0.6ohm to 13Kohm no dead spots. sometimes if I try to move a second time too soon there is just a click but no movement, but sometimes a fault code beep 4-1 which is not listed in the back of the book. any insights, hints or solutions? 2009 pride celebrity dx sport
  • nico kuiper
    nico kuiper Mar 09, 2016
    I am in Vancouver Canada. The controller being faulty makes sense as it will not go in reverse. Are controllers still available? how far away are you?
  • Health & Beauty Master
  • 1,399 Answers
Hi Nico, first of all let's check those brushes, at worse it 's the controller as i see that before...
Have you check the wiring from the throttle pot to the controller ?
One last thing , the speed pot,,short the two white wires ? and see if there is a improvement as it very hard to sometimes to find a faulty pot purely by taking resistance readings,..
Regards
Rob
Posted on Mar 08, 2016
Testimonial: "I did check the resistances from the plug at the controller, so it checked the harness at the same time (thought possible break where the tiller pivots) The motor resistance is 0.8ohm but will check the brushes. any idea what the code 4-1 means? I'll try shorting the speed pot tonight."
  • Rob Hill
    Rob Hill Mar 08, 2016
    Error 4,1 CURRENT SENSE FAULT current sense fault 1. Short in motor or in motor wiring.
    2. Controller failure. *
    I can repair those controllers quite cheaply , where are you located please ..
    Regards
SOURCE:
Security light comes on and vehicle wont start
You could try resetting the computer. The car maybe in lockout mode. Try turning your car over….leave the ignition on. Wait exactly 10 min. Then try turning over again….again leave the key on. Wait exactly 10 min and do it a third time….this time the car should start…maybe run a lil rough while it relearns the processes of your vehicle again. It is important to wait the exact 10 min each time. You will probably need a battery charger or a set of jumper cables because if your car goes low during this process it will not work. Good luck and I hope this works.
Apr 15, 2010 | 2003 Pontiac Grand Am
Wont start and a ticking noise is coming from the auto hdlp ctrl
Apr 14, 2010 | 2001 Pontiac Grand Am SE
What would cause no spark and no fuel in my 1997 sunfire
Apr 10, 2010 | 1997 Pontiac Sunfire
Replaced engine w one from pic n pull got it back together and it is stuck in park as if a theft system will not let it move i have disconnected the cable to transmission and the shifter will not move out...
Mar 28, 2010 | 2004 Pontiac Grand Prix
My car want start it turns over but want start
Mar 27, 2010 | 1994 Pontiac Grand Am
Changed ignition switch and now the car thinks it's being stolen. It shuts off the gas flow. Does anyone have the code or know how to reprogram for the new switch?
YOU HAVE A PASSLOCK SYSTEM WHEN YOU TURN THE KEY THE COMPTER READS IT OK OK RESET YOU MUST DO THIS
1 TRY TO START VEH AND LEAVE IN RUN POSITION FOR 10 MINS
2 DO IT AGAIN
3 DO IT AGAIN
FOR A TOTAL OF 30 MINS THIS DOESNT ALWAYS TAKE THE FIRST TIME. MAY HAVE TO DO IT MORE THEN ONCE AGAIN TRY TO START VEH AND JUST LET THE KEY GO AND WAIT 10 MIN 3 TIMES
Feb 11, 2010 | 2003 Oldsmobile Alero
Stalling
Check your batteries, they might be ready to die. Stalling is a sign your are not getting enough power to the scooter and when you do, it runs until they run low again. Kinda like a cell phone batt, ones it dies and you wait awhile you can get it started but only for a couple of minutes before dying again.
Apr 14, 2009 | Echo 3 TE SL7 3 New Electric Scooter by...
Instructions for Sunbeam clock model # 882-495
Move the second button from the left to set, enter the time in 24 hour format via the HH and MM buttons, then move the button to start. The far left switch, on/auto.off is for the chime. Set to on for 24 hour alarms, set to auto for no chime from 11pm til 6am, set to off, to turn it off.
Mar 29, 2008 | Office Equipment & Supplies
Health & Beauty Logo
150 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
